so had my lr4 working well. disconnected the jp3 to install the permanent strut plates. once it was back together my end stops weren’t working. seem to have sorted out that issue but now the stepper motors won’t move at all. they all have power when the machine is powered on.
i’ve tried reflashing the firmware but keep getting an error asking me to try a slower speed.
any help greatly appreciated!
this is the error log:
\[MSG:INFO: FluidNC v3.9.9 https://github.com/bdring/FluidNC\]
\[MSG:INFO: Compiled with ESP32 SDK:v4.4.7-dirty\]
\[MSG:INFO: Local filesystem type is littlefs\]
\[MSG:INFO: Configuration file:config.yaml\]
\[MSG:DBG: Running after-parse tasks\]
\[MSG:DBG: Checking configuration\]
\[MSG:INFO: Machine LowRider\]
\[MSG:INFO: Board Jackpot3 TMC2226\]
\[MSG:INFO: UART1 Tx:gpio.16 Rx:gpio.4 RTS:NO_PIN Baud:115200\]
\[MSG:INFO: I2SO BCK:gpio.22 WS:gpio.17 DATA:gpio.21Min Pulse:2us\]
\[MSG:INFO: SPI SCK:gpio.18 MOSI:gpio.23 MISO:gpio.19\]
\[MSG:INFO: SD Card cs_pin:gpio.5 detect:NO_PIN freq:20000000\]
\[MSG:INFO: Stepping:I2S_STATIC Pulse:2us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms\]
\[MSG:INFO: User Digital Output: 0 on Pin:gpio.26\]
\[MSG:INFO: User Digital Output: 1 on Pin:gpio.27\]
\[MSG:INFO: User Digital Output: 2 on Pin:gpio.0\]
\[MSG:INFO: User Digital Output: 3 on Pin:gpio.2\]
\[MSG:INFO: Axis count 3\]
\[MSG:INFO: Axis X (3.000,1223.000)\]
\[MSG:INFO: Motor0\]
\[MSG:DBG: TMCStepper Library Ver. 0x703\]
\[MSG:INFO: tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110\]
\[MSG:INFO: Neg Limit gpio.25\]
\[MSG:DBG: Neg Limit 1\]
\[MSG:INFO: Axis Y (3.000,2443.000)\]
\[MSG:INFO: tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110\]
\[MSG:INFO: Neg Limit gpio.33\]
\[MSG:INFO: Motor1\]
\[MSG:INFO: tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110\]
\[MSG:INFO: Neg Limit gpio.35\]
\[MSG:INFO: Axis Z (-147.000,3.000)\]
\[MSG:INFO: tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110\]
\[MSG:INFO: Pos Limit gpio.32\]
\[MSG:DBG: Pos Limit 1\]
\[MSG:INFO: tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110\]
