Hello all,
Over the past several months I’ve put together a LR4. Cut dimensions are 1250 y and 610 x. I try not to play the comparison game too much but I see other users reaching impressive speeds and/or accuracy and I am struggling to do either at this point. Some parts come out +/- 0.25mm, which is perfectly fine, but I have zero consistency. Just last night I attempted to cut several 100mm circles experimenting with depth of cut and climb vs conventional. I will attach the code I was running and some pictures as soon as I can get them but looking for some advice because I believe this is a very capable machine, but I’m about ready to throw in the towel.
I started the machine with all PLA parts, but in the process of chasing repeatable accuracy I have changed the core and the strut pieces to Annealed PET-CF. My uprights are still PLA. The reason for the change (in my mind anyway) is the machine is in an uninsulated garage and the temperatures can get north of 110 deg F in the summer. My thought was perhaps this is causing the PLA to soften and add flex, but there doesn’t seem to be any major change as a result.
I originally used the cheapest 9mm belt I could find on Amazon, I think it was the one linked in the BOM, but have since upgraded to a Gates GT2 9mm belt and that made no difference.
I started with a Carbide ER11 router that I got on sale, and have since changed to a Makita RT0701C thinking maybe the router was the problem. This I think helped a bit but hard to definitively say.
I’ve used a variety of bits from 1/8-1/4 most of them fairly inexpensive, but I’ve had the best luck with 1/4 and 1/8 bits from CIC and I am currently running a Whiteside 1/8 2 flute upcut bit. This bit has been able to get me within 0.25mm accuracy, but my testing yesterday was giving me ±1.5mm accuracy.
On to my observations from yesterday. The first test was a DOC cut. I arranged 6 100mm circles to be cut from 12mm Baltic birch using 1mm doc to 6mm doc at 500mm/min XY and 200mm/min Z. These were cut using Conventional milling direction. The 1mm DOC was the closest to accurate but was still 0.5mm too small in both X and Y. Each successive cutout was worse by about 0.25mm in both directions, ending up with the 6mm DOC being 1.5mm too small in the X and just shy of 1mm short in the Y. X has characteristically been worse than y.
The second test was 2 100mm circles cut in 12mm baltic birch at 3mm doc and 1000mm/min XY using a simple trace cut from Fusion. One circle was Conventional cut, the other was climb cut. Other than that both circles were identical in terms of setup. The conventional cut was 99.5mm in both directions and the climb was 101.5mm in both directions.
My main observation is where the bit plunges into the material I can see on the finished piece where the bit deflected, if you will. On the conventional cut pieces, where the bit goes in is raised (ie the bit flexes into the piece) and on the climb cut piece, the bit walks out.
I took the suggestion of these forums and tried to find loose bolts, but everything appears to be tight. I did notice yesterday that I can move the core in both directions about 1mm or more with out causing the stepper to skip. I don’t believe this is loose bolts as it almost seems to be related to belt stretch (I think I can see the belts stretch).
Sorry if this is a repeat question, I’ve spent considerable time looking for similar problems with no luck. Curious if anyone has any suggestions or solutions as this is getting extremely frustrating for me. I also apologize if this was a mess of info and if I left something out just let me know.
Thanks,
Ben
