Hi Ryan, is it possible to print with a Ender 3 ?
What is your build volume? If I am not mistaken, there are several sizes of an ender 3.
On the other hand I have not released the files yet, it will be more clear as soon as I do.
Hi Ryan, build volume Ender 3 V2 is X-220mm Y-220mm Z-250mm
Ender 3 MAX is X-300mm Y-300mm Z-340mm
Grts Dirk
You will be fine, the biggest print is about 175ish all around
Thanks, i just download the print files
I will make them on my LR2
THANKS
No that is not how to print that one. Print it as shown on printables, that is how it should be oriented and should fit on your bed diagonally.
As a general reminder, Ryan orients the prints intentionally, and you shouldn’t put one of his designs with a different face down.
A lot of models out there aren’t oriented in print direction, but Ryan has designed the parts based on that direction.
Rotation the XY plane is usually NBD. But keep the bottom face down.
What size bed would you need for the YZ just out of curiosity?
200x250
Lol, that’s gold!
Regards from a fellow woodworker
