azab2c
(Aza B2C)
February 25, 2023, 7:12am
6
Taking a look, somewhere in Der Froschkönig - Lowrider 3 in Oldenburg, Germany ? Vaguely recall Ryan mentioning he might be modding the dust collector too, I might have gotten that wrong?
So most of your cutting area is a vacuum table right, effectively helping to pull dust onto areas not covered by Stock? Must be way more powerful Vac than my relatively cheap ~4HP shop vac from Home Depot.
[Screenshot_2023-02-01-10-47-40-174_com.simplemobiletools.gallery.pro]
Things I learned about acrylic: If you use trochoidal, make sure that you have a very good dust collection. There will be big shavings of it and they do not compromise. After the job, my core made hobbling sounds because of acrylic shavings sticking to the bearings, cleaning it was really nasty. Also, on the Y where the bearings roll over the wood, you can clearly see markings the acrylic made in the wood when the bearings …
