After cutting a couple of brace test pieces on the LR2 out of a bit of scrap ply I had this curious feeling that we’ve brought the new puppy home before the old dog is dead!
My intention has always been to attempt the final ones out of Composite, so rather than waste any energy fiddling with the LR2, I thought I’d try a different strategy for the temporary struts. I’ll sort the final versions after the LR3 is finally tuned. It helps that I have a shed full of tools that haven’t been fired up in a while and need a bit of routine maintenance.
This is probably a viable way of making struts for anyone who owns basic woodworking machinery and if you have a little experience, it takes about the same time as generating the g-code to cut the parts on the CNC (and yes it is quieter and just as much fun!).
It’s not difficult to cut a very accurate rectangle with even a basic table saw. I like to tape parts like this together to make sure they are cut to identical length, and of course it makes for one third of the drilling.
I usually mark wooden parts out on a bit of masking tape so if I make a mistake there’s no mucking around with multiple marks, just replace the bit of tape and get on with it.
I have a pillar drill too, so drilling clean square holes after centre punching isn’t much of a challenge either, just use the first row as a template for the rest.
Of course if I change my mind I can always cut the truss in later.
