Do any of you use vectric aspire to generate toolpaths for a lowrider? I saw here on the forum that some users have undertaken to create a marlin post processor to use with aspire (honor to you) but I wanted to know if anyone managed to use vtransfer to send gcode to our marlin based cnc, nothing to take away to RH but I would like to understand if anyone has managed to use vtransfer since in theory the program gives the possibility to create a custom profile! I ask here why the official vectric documentation does not explain anything about how to do this.
I tried using Vtransfer with Marlin Post Processor, it does not work.
Information as below from Vectric site.
VTransfer is a small helper application provided by Vectric to simplify the process of sending toolpaths to some Grbl-based controllers. You should run VTransfer on the PC which your CNC machine is connected to via a USB serial connection.
Vtransfer lavoro solo con grbl… Capito
