LowRider 4 Sandbox - Virtual in Browser
DO NOT TRUST THIS. I AM A DEVELOPER BUT THIS IS CRAZY VIBE CODING. CLAUDE DIDN’T SAY NO TO MY CRAZY IDEAS. IT IS NOT COMPLETE AND THERE ARE DEFINITELY THINGS WRONG. THE V1E DOCS ARE THE SOURCE OF TRUTH.
If you’ve been following along in this thread, you’ll have realized that I’ve lost my mind.
Somehow I started messing with a FreeCAD MCP and I went down a spiderweb of rabbit trails.
I’ve been building a 3D model of the LowRider 4, and it’s now a web page anyone can use.
The Github has a good detailed description of what it does and how to get started.
You can use this for real in your browser. You just need to download some files off Printables.
Enter your cutting area and it draws the whole machine at that size, using V1E’s actual printed part files. Each part is placed from its holes and mating features, and every fastener is checked.
What it does
  • Size it: any cutting area in inches or mm. It works out the braces, rails, belts and table, and gives you V1E’s calculator cut list.
  • Build it:
    • the full BOM for your size, with hardware counts
    • strut plates as DXF / SVG, or as G-code to cut them on the machine itself (V1E’s build order, with the temporary struts)
    • V1E’s JP3_LR config.yaml with max_travel_mm set for your size
  • Look inside it: hide parts by assembly or by printed / hardware, or open any assembly on its own with its parts list. You can explode it along the bolt lines, cut a section, see the hardware in X-ray, and measure between hole centers.
  • Run it:
    • play G-code and watch the stock get carved, with probing, M0 pauses and tool changes
    • or boot the real FluidNC firmware in the browser: home on the switches (each Y motor squares on its own switch), jog, probe, use the console
    • there’s also a FluidTouch pendant on the table you can drive
  • Extras:
    • Machine sounds: steppers, router, shop vac (plus a “robot noises” mode for fun)
    • A workshop around the machine, where you can enter your building size to see how much room you have
    • VR on a PC headset (I haven’t tested this at all), and links that share your exact build
The part files aren’t on the site. They’re V1E’s, so you download them yourself, free from V1E’s Printables pages: the LowRider 4, the Kobalt mount + dust shoe, the Jackpot3 box and the Peter Plates. Drop the zips on the page. They’re read in your browser and nothing is uploaded. The page links to each download.
Please double-check before you cut, print or buy. It’s still being worked on. I’ve checked the model against V1E’s photos and my own measurements, but treat the numbers, BOM, G-code and config as a starting point and verify them against the V1E docs.
This video was generated by a gcode file with special comments.
Pushed an update to add some lighting and shadows. Looks better.
Is this going to end up being our new Gcode simulator? It would catch Ui, firmware, and table size issues all in one shot.
I think it will get there.
Note there are 2 simulation modes: Basic which interprets the gcode itself, and FluidNC which runs it for real. There are some changes in a sim fork I made so you can speed it up.
Right now, you can’t use WebUI or FigUI with this. However, I have a change coming where you can put a UI (or multiple) on the virtual flash or SD card and open that in a new tab/window from the simulator. It works.
There are also some things that rely on my special gcode to set bits and stock size. I’m making some changes to allow you do that manually like you would in real life.
I also have some planned changes for an imperfect machine. Right now, the spoilboard is perfectly flat and the machine is perfectly square and the router is perfectly trammed. So, this will allow for things like simulating how squaring works and surfacing a spoilboard. I even plan on being able to keep all the cuts in the spoilboard so you can run a surfacing job to see how it cleans it up.
There are interesting things that get discovered. Like when trying to get everything to line up, the one side was higher than the other. Some of that was errors in positioning, but after all that, it still says that one side is 0.25mm higher than the other. I’m using the parts for EMT (29.5). Makes me wonder if the 30 would line up perfectly.
I think this will be simulated accurately enough that AI can be used to create plugins and custom gcode scripts and such.
Love how far and fast this experiment/project is actualizing.
Considered Material Removal Rate ( MRR ) and Chip Load tracking/monitoring? Think GitHub - vector76/jamiecam: Toolpath Generator · GitHub does or planned to.
Like the idea of “competitive” CNC where MRR maxxing community configs and gcodes are shared .
Man, I’ve been pushing back on using Ai, but its inevitably coming down on me. So cool what things people can do.
Thist be helpfull for new people to simulate their stuff to better understand how the lr4 it works aswell! And I thought the lr4 couldn’t get the cnc entry bar any lower.
We need a simulated fire where the simulated shop burns down if there are five minutes without user interaction. :grinning_face_with_smiling_eyes:
Oi, that feels personal :distorted_face: :rofl:
And some simulated boxes and dust and spare parts that slowly pile up on the table after each week of non use. This would mimic the real life feeling that “by the time I clean that mess I could have done it by hand”.
Either that, or we have!
This is so beyond my comprehension in every respect that I just sit and stare in awe!!
I made a comparison
You know there’s an option in there to change the part colors.
Not sure if you turned on the simulated sound.
I’ve got a bunch of updates coming.
How cool! I’m going to explore some more. I love this forum because you get to follow several projects at the same time—I’ve found my own little corner here with people who share the same tastes as me. :upside_down_face:
I am so skeptical of AI, but some things are really cool about it (like the small programs I can just create that do stuff I wanted to do forever).
This is one of those things. I am definitely going to use this in my Makerspace Club so they can learn to work with a CNC before they are allowed to use the real one. :slight_smile:
This is so cool! I am considering not bothering to cut real wood anymore, just simulate my projects! No more sanded knuckles, splinters. Big savings on equipment and wood stock!
Seriously, very cool project
I just pushed out a ton of updates. It’s a little less vibe coding and a little more “agentic engineering”. Still things to tweak, add, and test but it has significant improvements.
I particularly like the in app “help” videos. Shows things like an intro, why homing matters, probing and zeroing, squaring, etc. I really like that you can now have an imperfect machine (out of square/tram) to the point that you can run a surfacing job and see the lines from being out of tram.
There’s also now links to the V1E, Hawiwe, and Northwoods stores. And the Jackpot on Elecrow.
This doesn’t even adequately cover the changes but I didn’t want to put a wall of text:
  • Help videos: a Help ▾ menu with five videos that play live in the page, including the tour.
  • Router bits: My bits (your own bit library), all six bit shapes, a popup at bit changes, and Where to buy links in the BOM.
  • Front plate designer
  • My machines: saves more than one machine in the browser.
  • Printed look: layer lines and filament colors on the printed parts.
  • Phone layout
  • Part files: a welcome card, a Parts chip, and placeholder parts until your files are loaded.
  • Page layout: the page is now split into Design and Run, with steps in Design, layers on the view, and a console in Run.
  • FluidNC is the only machine, and the old Basic mode is now called Preview.
  • Touch plate and probe clip: animated probing, and the router won’t start while the clip is still on.
  • As built: a model of an imperfect machine (out of square, out of tram).
  • Table: a separate spoilboard, plus a torsion box option.
  • Setting up by hand: you place the stock, bit and touch plate on the table yourself.
  • Smaller fixes: a new page icon, the 68 mm hose, and updated README screenshots.
Oh yea, and you can now install WebUI v2/v3 and/or FigUI on the virtual SD/Flash and run it in a popup connected to the virtual machine.
Working on a safety video…
fire
Whatever you do, avoid implementing simulated gravity, part-level FEM, and distributed mesh connected generative machine creation. That’s how it all started.
Don’t let the Clankers grind you down!
Kyle
I realize saying this is unbelievably cool is neither particularly insightful nor helpful and is a wild understatement, but I am so blown away I don’t know what to say :weary_cat:
Thanks. I’m still shocked this exists. I didn’t plan to make this but I like where it ended up. I’ve learned awhile ago that silly ideas can turn out better than expected and even if it doesn’t, you’re still going to learn something along the way.
Using AI is weird. On one hand, I’ve had a lot of good ideas to get this where it is. On the other hand, I haven’t written any code. There are parts of this where I could make or modify this myself. There are others that are way outside my skillset and either I couldn’t reasonably implement or would have taken a significant amount of learning and time.
Thanks for following along.
