I use fusion and a post processor for linux cnc, plasma specific I believe. linked in the plasmac instructions page from what I remember. I might have even linked it in my build thread a few weeks ago.
Cool. In relation to getting things setup more properly, I made a gauge to measure the real world distance of the pierce height during the pause of a probe test, which is correct if the Float Travel value is right, and off if it is not, and it seems my float travel is right at 0.2" — I think I have successfully conducted a probe test and verified my pierce height.
I noticed how much the material bends in your video, I would make sure to set it for thicker material that doesn’t bend, and don’t worry too much about the bendy stuff since it is simple to cut and flame height matters less.
In 1/8" I can start to see the flame height in the walls of my cut, that is when I started adjusting mine. Angled open towards the top too high, open to the bottom cutting too slow. Seems I can’t get too close.
It’s supposed to clearing up here so I can do more cuts probably this weekend!!! Maybe even make my strut plates.
Are you talking about those plates on the lr3 gantry? If so how flat do those plates need to be? I assume as the assembly comes together it more or less would pull them flat? Also, what material?
I used a thicker piece of steel when doing my probe testing (as recommended in the documentation for setting up QTplasmaC), measuring my floating Z travel so that I could get the settings correct for pierce height and cut height. While in an ideal world, the floating Z travel distance should not vary from material to material, the thinner and more bendy a sheet of steel is, the more flawed the Z travel fluctuation issue, but also the thinner stuff is easier to cut even if the height is off ever so slightly. So it’s a wash.
The sound logic (which I missed at first out of newness and overload) for inputting the float Z travel in its own parameter (instead of my newbie mistake of lumping it in with pierce height and cut height) is so that the parameters for pierce height and cut height can vary from material setting to material setting.
Before, or at least as soon as, I ever need to cut anything thicker, I will definitely set up a material setting for that thicker material. In the meantime the only steel I plan on cutting in the near future is 20 gauge (what was shown in my first test cut) and 18 gauge. All thin stuff.
Beyond the QTplasmaC default material setting, I currently have only one material configuration, and it is for the 20 gauge that I have sitting on it. But creating new material configs is a breeze, and getting the cut height honed in for each should be straightforward, especially given your advice about whether the sides of the cut are angled either upwards or downwards.
You’re my hero. I was all proud of my control box, your whole setup is next level.
Superb!!
Thanks! I am just the next guy to follow in the footsteps of some geniuses who already used plasma cutters on LowRiders, especially using the tutorials from @kd2018 and lots of advice and guidance from both him and @vicious1! And @kd2018 apparently followed after someone else who did plasma work before him, which I have not yet connected with!
So, I drew up a pretty complex design for plasma cutting a gift for a friend, and I used Fusion 360 for CAM with the LinuxCNC plasma post processor, and I got a successful post of the .NGC file.
I think I may have mentioned this video before. It’s a little bit old in that the screen shots don’t still look exactly like that, but the overall workflow is still basically the same. (It was posted some 4 years ago.)
It took me a few tries to get it all working right. One thing I had to find and get entered was the right kerf width for the PTM80 Torch.
Like ESTLcam does, it lets you watch an animated preview of the planned cuts. I like that.
Based on the preview, I think I’m on the right track.
Well, I went to run the posted NGC file in LinuxCNC QTPlasmaC and got a lot of error notices saying “M3 command detected before movement.”
I need to go check out Ryan’s thread to see how he solved this in the post processor.
I havn’t used fusion or the pp so I probably can’t be of much help.
I did a quick google search on the error you provided and according to this thread it looks like qtplasmac expects to see an explicit G0 or G1 movement command in the line directly preceeding the M3 (cut start) command. And apparently the hobby version of fusion is a problem. Qtplasmac M3 detected error. - LinuxCNC
I’m curious to see your ngc file? maybe a real quick “post post processing” with a quick python script would remedy this.
Thanks! During my searching I found the same article and others, and although I tried manually editing the NGC file, I seem to lack the knowledge to do so in a way that helped.
Below is my NGC file (attached) as well as a copy and paste of part of it (which is scrollable inside the code box). The full copy and paste was too much.
1001 - McClain Family Saving Lives Since 1986.ngc.zip (244.3 KB)
S1000
(McClain Family Saving Lives Since 1986)
(Machine)
( vendor: Hynade)
( model: CUT60DN)
( description: LowRider v3 Plasma Table withHynade CUT60DN Plasma Machine)
N10 G20
N11 G90 G17
N12 G28 G91 Z0.
N13 G90
(2D Profile3)
N14 G54
N16 G0 G43 X5.7031 Y8.8824 Z0.6 H1
N18 Z0.
N19 M3
N20 G4 P 0.5
N21 G1 X5.6772 Y8.8674 F118.11
N22 Y8.8511 F180.
N23 X5.975
N24 Y8.9243
N25 X5.6772
N26 Y8.8674
N27 X5.7031 Y8.8524
N28 M5
N29 G4 P 0.5
N30 G0 Z0.2
N31 X5.581 Y9.033
N32 Z0.
N33 M3
N34 G4 P 0.5
N35 G1 X5.607 Y9.048 F118.11
N36 Y9.6252 F180.
N37 X5.5003
N38 Y8.8511
N39 X5.607
N40 Y9.048
N41 X5.581 Y9.063
N42 M5
N43 G4 P 0.5
N44 G0 Z0.2
N45 X5.7245 Y9.2489
N46 Z0.
N47 M3
N48 G4 P 0.5
N49 G1 X5.7095 Y9.2748 F118.11
N50 X5.6772 F180.
N51 Y9.2113
N52 X5.9413
N53 Y9.2748
N54 X5.7095
N55 X5.6945 Y9.2489
N56 M5
N57 G4 P 0.5
N58 G0 Z0.2
N59 X5.7537 Y9.5993
N60 Z0.
N61 M3
N62 G4 P 0.5
N63 G1 X5.7387 Y9.6252 F118.11
N64 X5.6772 F180.
N65 Y9.5521
N66 X5.975
N67 Y9.6252
N68 X5.7387
N69 X5.7237 Y9.5993
N70 M5
N71 G4 P 0.5
N72 G0 Z0.2
N73 X5.8869 Y10.3093
N74 Z0.
N75 M3
N76 G4 P 0.5
N77 G1 X5.8708 Y10.284 F118.11
N78 X5.8772 Y10.2717 F180.
N79 X5.9851
N80 X5.814 Y10.5671
N81 G2 X5.8196 Y10.5851 I0.0111 J0.0064
N82 G1 X5.8358 Y10.5928
N83 X5.8508 Y10.6011
N84 X5.8649 Y10.6104
N85 X5.8782 Y10.6206
N86 X5.8906 Y10.6317
N87 X5.9021 Y10.6438
N88 X5.9129 Y10.6568
N89 X5.9229 Y10.6708
N90 X5.9317 Y10.6855
N91 X5.9394 Y10.7009
N92 X5.9459 Y10.7172
N93 X5.9512 Y10.7343
N94 X5.9554 Y10.7522
N95 X5.9584 Y10.771
N96 X5.9602 Y10.7906
N97 X5.9608 Y10.8112
N98 X5.9604 Y10.8247
N99 X5.9593 Y10.8378
N100 X5.9575 Y10.8506
N101 X5.955 Y10.863
N102 X5.9518 Y10.875
N103 X5.9479 Y10.8866
N104 X5.9433 Y10.8979
N105 X5.938 Y10.9089
N106 X5.9319 Y10.9196
N107 X5.9255 Y10.93
N108 X5.9185 Y10.94
N109 X5.9111 Y10.9496
N110 X5.9033 Y10.9587
N111 X5.895 Y10.9674
N112 X5.8863 Y10.9758
N113 X5.8771 Y10.9837
N114 X5.8675 Y10.9912
N115 X5.8576 Y10.9982
N116 X5.8474 Y11.0047
N117 X5.8369 Y11.0108
N118 X5.826 Y11.0164
N119 X5.8149 Y11.0214
N120 X5.8035 Y11.026
N121 X5.7916 Y11.0301
N122 X5.7796 Y11.0338
N123 X5.7676 Y11.037
N124 X5.7556 Y11.0397
N125 X5.7435 Y11.0419
N126 X5.7313 Y11.0436
N127 X5.7192 Y11.0448
N128 X5.7071 Y11.0456
N129 X5.6947 Y11.0458
N130 X5.6523
N131 Y10.9727
N132 X5.6926
N133 X5.6929
N134 X5.7051 Y10.9724
N135 G2 X5.7056 I-0.0002 J-0.0128
N136 G1 X5.7172 Y10.9717
N137 G2 X5.7178 Y10.9716 I-0.0008 J-0.0128
N138 G1 X5.7287 Y10.9704
N139 G2 X5.7294 Y10.9703 I-0.0014 J-0.0127
N140 G1 X5.7398 Y10.9686
N141 G2 X5.7405 Y10.9684 I-0.0021 J-0.0126
N142 G1 X5.7502 Y10.9662
N143 G2 X5.751 Y10.966 I-0.0028 J-0.0125
N144 G1 X5.7601 Y10.9633
N145 G2 X5.761 Y10.963 I-0.0036 J-0.0123
N146 G1 X5.7695 Y10.9598
N147 G2 X5.7704 Y10.9594 I-0.0045 J-0.012
N148 G1 X5.7783 Y10.9557
N149 G2 X5.7789 Y10.9554 I-0.0054 J-0.0116
N150 G1 X5.7863 Y10.9514
N151 G2 X5.7869 Y10.951 I-0.0061 J-0.0112
N152 G1 X5.7939 Y10.9467
N153 G2 X5.7945 Y10.9463 I-0.0067 J-0.0109
N154 G1 X5.8011 Y10.9418
N155 G2 X5.8016 Y10.9414 I-0.0073 J-0.0105
N156 G1 X5.8078 Y10.9366
N157 G2 X5.8084 Y10.9361 I-0.0078 J-0.0101
N158 G1 X5.8141 Y10.9311
N159 G2 X5.8146 Y10.9306 I-0.0085 J-0.0096
N160 G1 X5.8199 Y10.9253
N161 G2 X5.8205 Y10.9247 I-0.009 J-0.009
N162 G1 X5.8253 Y10.9192
N163 G2 X5.8259 Y10.9185 I-0.0096 J-0.0084
N164 G1 X5.8302 Y10.9128
N165 G2 X5.8307 Y10.9121 I-0.0102 J-0.0077
N166 G1 X5.8385 Y10.9003
N167 G2 X5.8391 Y10.8992 I-0.0107 J-0.007
N168 G1 X5.8454 Y10.8871
N169 G2 X5.846 Y10.8858 I-0.0113 J-0.0059
N170 G1 X5.8508 Y10.8735
N171 G2 X5.8512 Y10.8722 I-0.0119 J-0.0046
N172 G1 X5.8546 Y10.8597
N173 G2 X5.8548 Y10.8588 I-0.0124 J-0.0033
N174 G1 X5.8573 Y10.8464
N175 G2 X5.8574 Y10.8458 I-0.0126 J-0.0025
N176 G1 X5.8591 Y10.8342
N177 G2 X5.8592 Y10.8335 I-0.0127 J-0.0019
N178 G1 X5.8602 Y10.8226
N179 G2 X5.8603 Y10.8218 I-0.0127 J-0.0012
N180 G1 X5.8606 Y10.8116
N181 G2 Y10.8109 I-0.0128 J-0.0004
N182 G1 X5.8604 Y10.799
N183 G2 Y10.7986 I-0.0128 J0.0002
N184 G1 X5.8599 Y10.7872
N185 G2 X5.8598 Y10.7867 I-0.0128 J0.0006
N186 G1 X5.8588 Y10.7757
N187 G2 Y10.7752 I-0.0127 J0.0011
N188 G1 X5.8575 Y10.7648
N189 G2 X5.8574 Y10.7642 I-0.0127 J0.0016
N190 G1 X5.8557 Y10.7542
N191 G2 X5.8556 Y10.7536 I-0.0126 J0.0021
N192 G1 X5.8535 Y10.7441
N193 G2 X5.8534 Y10.7435 I-0.0125 J0.0027
N194 G1 X5.8509 Y10.7345
N195 G2 X5.8507 Y10.7338 I-0.0124 J0.0033
N196 G1 X5.8479 Y10.7253
N197 G2 X5.8477 Y10.7247 I-0.0122 J0.004
N198 G1 X5.8446 Y10.7166
N199 G2 X5.8444 Y10.7162 I-0.0119 J0.0046
N200 G1 X5.8411 Y10.7086
N201 G2 X5.8408 Y10.7079 I-0.0117 J0.0051
N202 G1 X5.8372 Y10.7008
N203 G2 X5.8369 Y10.7002 I-0.0114 J0.0057
N204 G1 X5.8331 Y10.6936
N205 G2 X5.8327 Y10.6929 I-0.0111 J0.0063
N206 G1 X5.8287 Y10.6867
N207 G2 X5.8282 Y10.686 I-0.0107 J0.007
N208 G1 X5.8239 Y10.6803
N209 G2 X5.8233 Y10.6795 I-0.0103 J0.0077
N210 G1 X5.8188 Y10.6743
N211 G2 X5.8182 Y10.6736 I-0.0097 J0.0084
N212 G1 X5.8134 Y10.6688
N213 G2 X5.8126 Y10.6681 I-0.0091 J0.009
N214 G1 X5.8026 Y10.6595
N215 G2 X5.8016 Y10.6587 I-0.0084 J0.0097
N216 G1 X5.7911 Y10.6513
N217 G2 X5.7898 Y10.6505 I-0.0073 J0.0105
N218 G1 X5.7787 Y10.6446
N219 G2 X5.7774 Y10.644 I-0.0061 J0.0113
N220 G1 X5.7658 Y10.6393
N221 G2 X5.7646 Y10.6389 I-0.0048 J0.0119
N222 G1 X5.7526 Y10.6353
N223 G2 X5.7517 Y10.6351 I-0.0036 J0.0123
N224 G1 X5.7398 Y10.6325
N225 G2 X5.7387 Y10.6323 I-0.0027 J0.0125
N226 G1 X5.7267 Y10.6308
N227 G2 X5.7257 Y10.6307 I-0.0016 J0.0127
N228 G1 X5.7137 Y10.6302
N229 G2 X5.7132 I-0.0005 J0.0128
N230 G1 X5.6523
N231 Y10.5604
N232 X5.6701
N233 X5.678
N234 X5.6848
N235 X5.6908
N236 X5.6959
N237 X5.7002
N238 X5.7034
N239 X5.7062 Y10.5605
N240 X5.7083 Y10.5607
N241 X5.7101 Y10.5609
N242 G2 X5.7106 I0.0014 J-0.0127
N243 G1 X5.7143 Y10.5612
N244 G2 X5.7148 I0.001 J-0.0128
N245 G1 X5.7181 Y10.5613
N246 G2 X5.7299 Y10.5545 I0.0005 J-0.0128
N247 G1 X5.8708 Y10.284
N248 X5.9008 Y10.2827
N249 M5
N250 G4 P 0.5
N251 G0 Z0.2
N252 X5.5401 Y11.0198
N253 Z0.
N254 M3
N255 G4 P 0.5
N256 G1 X5.5251 Y11.0458 F118.11
N257 X5.4774 F180.
N258 Y10.2717
N259 X5.582
N260 Y11.0458
N261 X5.5251
N262 X5.5101 Y11.0198
N263 M5
N264 G4 P 0.5
N265 G0 Z0.2
N266 X5.6988 Y12.4243
N267 Z0.
N268 M3
N269 G4 P 0.5
N270 G1 X5.6728 Y12.4093 F118.11
N271 Y11.6922 F180.
N272 X5.7796
N273 Y12.4663
N274 X5.6728
N275 Y12.4093
N276 X5.6988 Y12.3943
N277 M5
N278 G4 P 0.5
N279 G0 Z0.2
N280 X5.6011 Y13.1548
N281 Z0.
N282 M3
N283 G4 P 0.5
N284 G1 X5.627 Y13.1698 F118.11
N285 Y13.8869 F180.
N286 X5.5204
N287 Y13.1128
N288 X5.627
N289 Y13.1698
N290 X5.6011 Y13.1848
N291 M5
N292 G4 P 0.5
N293 G0 Z0.2
N294 X5.7446 Y13.5105
N295 Z0.
N296 M3
N297 G4 P 0.5
N298 G1 X5.7296 Y13.5365 F118.11
N299 X5.6973 F180.
N300 Y13.473
N301 X5.9613
N302 Y13.5365
N303 X5.7296
N304 X5.7146 Y13.5105
N305 M5
N306 G4 P 0.5
N307 G0 Z0.2
N308 X5.7391 Y13.8398
N309 Z0.
N310 M3
N311 G4 P 0.5
N312 G1 X5.7541 Y13.8138 F118.11
N313 X5.995 F180.
N314 Y13.8869
N315 X5.6973
N316 Y13.8138
N317 X5.7541
N318 X5.7691 Y13.8398
N319 M5
N320 G4 P 0.5
N321 G0 Z0.2
N322 X7.7025 Y14.2423
N323 Z0.
N324 M3
N325 G4 P 0.5
N326 G1 X7.7295 Y14.2293 F118.11
N327 X7.7678 Y14.2554 F180.
N328 X7.7707 Y14.2721
N329 G2 X7.7708 Y14.2726 I0.0126 J-0.0022
N330 G1 X7.7736 Y14.2857
N331 G2 X7.7737 Y14.2861 I0.0125 J-0.0027
N332 G1 X7.777 Y14.2989
N333 G2 X7.7771 Y14.2994 I0.0124 J-0.0032
N334 G1 X7.7808 Y14.3119
N335 G2 X7.781 Y14.3123 I0.0123 J-0.0036
N336 G1 X7.785 Y14.3246
N337 G2 X7.7852 Y14.325 I0.0122 J-0.004
N338 G1 X7.7896 Y14.337
N339 G2 X7.7897 Y14.3374 I0.012 J-0.0044
N340 G1 X7.7945 Y14.3492
N341 G2 X7.7947 Y14.3496 I0.0118 J-0.0048
N342 G1 X7.7999 Y14.3611
N343 G2 X7.8 Y14.3615 I0.0117 J-0.0052
N344 G1 X7.8015 Y14.3645
N345 X5.6225 Y16.5435
N346 X5.6105 Y16.5547
N347 X5.598 Y16.5646
N348 X5.5849 Y16.5735
N349 X5.5713 Y16.5813
N350 X5.5572 Y16.5881
N351 X5.5427 Y16.5938
N352 X5.5278 Y16.5983
N353 X5.5127 Y16.6018
N354 X5.4973 Y16.6041
N355 X5.4818 Y16.6054
N356 X5.4663
N357 X5.4507 Y16.6043
N358 X5.4351 Y16.6021
N359 X5.4197 Y16.5986
N360 X5.4044 Y16.5939
N361 X5.3894 Y16.5881
N362 X5.3752 Y16.5813
N363 X5.3617 Y16.5735
N364 X5.3489 Y16.5649
N365 X5.3369 Y16.5554
N366 X5.3257 Y16.5452
N367 X5.3152 Y16.5341
N368 X5.3056 Y16.5224
N369 X5.2969 Y16.5101
N370 X5.2891 Y16.4972
N371 X5.2822 Y16.4837
N372 X5.2763 Y16.4697
N373 X5.2714 Y16.4553
N374 X5.2675 Y16.4406
N375 X5.2648 Y16.4255
N376 X5.263 Y16.4101
N377 X5.2625 Y16.3942
N378 Y16.3915
N379 Y16.3897
N380 Y16.3894
N381 Y16.387
N382 X5.2626 Y16.3842
N383 Y16.3808
N384 Y16.3769
N385 Y16.3768
N386 X5.2627 Y16.3726
N387 X5.2628 Y16.3678
N388 Y16.3677
N389 Y16.3624
N390 X5.2629 Y16.3567
N391 Y16.3566
N392 Y16.3504
N393 X5.263 Y16.3437
N394 Y16.3436
N395 X5.2631 Y16.3365
N396 X5.2632 Y16.3288
N397 Y16.3286
N398 X5.2631 Y16.3185
N399 Y16.3078
N400 Y16.3077
N401 X5.263 Y16.2963
N402 Y16.2962
N403 X5.2629 Y16.284
N404 Y16.2839
N405 X5.2627 Y16.271
N406 X5.2624 Y16.2574
N407 X5.2621 Y16.2431
N408 X5.2618 Y16.2282
N409 Y16.2281
N410 X5.2613 Y16.2126
N411 Y16.2125
N412 X5.2608 Y16.1963
N413 X5.2602 Y16.1795
N414 X5.2595 Y16.1621
N415 Y16.162
N416 X5.2587 Y16.144
N417 Y16.1439
N418 X5.2578 Y16.1254
N419 X5.2569 Y16.1063
N420 Y16.1062
N421 X5.2558 Y16.0865
N422 X5.2546 Y16.0663
N423 Y16.0662
N424 X5.2532 Y16.0455
N425 Y16.0454
N426 X5.2518 Y16.0242
N427 X5.2502 Y16.0025
N428 Y16.0024
N429 X5.2485 Y15.9802
N430 Y15.9801
N431 X5.2467 Y15.9575
N432 Y15.9574
N433 X5.2447 Y15.9344
N434 Y15.9343
N435 X5.2425 Y15.9108
N436 Y15.9107
N437 X5.2403 Y15.8868
N438 Y15.8867
N439 X5.2378 Y15.8623
N440 X5.2352 Y15.8376
N441 Y15.8375
N442 X5.2324 Y15.8124
N443 Y15.8123
N444 X5.2263 Y15.7609
N445 Y15.7608
N446 X5.2195 Y15.7081
N447 Y15.708
N448 X5.2119 Y15.654
N449 Y15.6539
N450 X5.2035 Y15.5989
N451 Y15.5987
N452 X5.1942 Y15.5426
N453 X5.1941 Y15.5425
N454 X5.184 Y15.4855
N455 X5.1839 Y15.4854
N456 X5.1728 Y15.4276
N457 Y15.4274
N458 X5.1607 Y15.369
N459 X5.1606 Y15.3688
N460 X5.1475 Y15.3098
N461 Y15.3096
N462 X5.1333 Y15.2501
N463 Y15.2499
N464 X5.1179 Y15.1901
N465 Y15.1899
N466 X5.1015 Y15.1299
N467 X5.1014 Y15.1297
N468 X5.0838 Y15.0695
N469 X5.0837 Y15.0692
N470 X5.0648 Y15.009
N471 Y15.0088
N472 X5.0446 Y14.9487
N473 X5.0445 Y14.9485
N474 X5.0231 Y14.8886
N475 X5.023 Y14.8883
N476 X5.0002 Y14.8287
N477 X5.0001 Y14.8285
N478 X4.9759 Y14.7693
N479 X4.9758 Y14.7691
N480 X4.9639 Y14.7414
N481 X4.9638 Y14.7412
N482 X4.9512 Y14.7129
N483 X4.9511 Y14.7128
N484 X4.9379 Y14.6839
N485 X4.9378 Y14.6838
N486 X4.9239 Y14.6544
N487 Y14.6543
N488 X4.9094 Y14.6243
N489 Y14.6242
N490 X4.8943 Y14.5937
N491 Y14.5936
N492 X4.8786 Y14.5625
N493 X4.8624 Y14.5309
N494 Y14.5308
N495 X4.8456 Y14.4987
N496 Y14.4986
N497 X4.8284 Y14.466
N498 X4.8283 Y14.4659
N499 X4.8106 Y14.4328
N500 Y14.4327
N501 X4.7924 Y14.399
N502 X4.7923
N503 X4.7737 Y14.3648
N504 X4.7736 Y14.3647
N505 X4.7546 Y14.3301
N506 X4.7545 Y14.33
N507 X4.735 Y14.2948
N508 Y14.2947
N509 X4.722 Y14.2716
N510 X4.9063 Y14.1953
N511 X4.9202 Y14.2203
N512 X4.9393 Y14.2548
N513 X4.9579 Y14.2889
N514 X4.9763 Y14.3226
N515 X4.9941 Y14.3559
N516 X5.0116 Y14.3888
N517 X5.0286 Y14.4212
N518 X5.0452 Y14.4532
N519 X5.0613 Y14.4847
N520 X5.0768 Y14.5158
N521 X5.0918 Y14.5463
N522 X5.1063 Y14.5765
N523 X5.1202 Y14.6061
N524 X5.1335 Y14.6352
N525 X5.1463 Y14.6639
N526 X5.1583 Y14.692
N527 X5.1789 Y14.7415
N528 X5.1987 Y14.7912
N529 X5.2177 Y14.8411
N530 X5.2361 Y14.8913
N531 X5.2538 Y14.9417
N532 X5.2707 Y14.9924
N533 X5.287 Y15.0433
N534 X5.3025 Y15.0945
N535 X5.3172 Y15.1458
N536 X5.3313 Y15.1975
N537 X5.3447 Y15.2493
N538 X5.3574 Y15.3014
N539 X5.3693 Y15.3538
N540 X5.3805 Y15.4064
N541 X5.3911 Y15.4592
N542 X5.4009 Y15.5123
N543 X5.4099 Y15.5656
N544 X5.4183 Y15.6191
N545 X5.4259 Y15.6729
N546 X5.4329 Y15.727
N547 X5.4391 Y15.7812
N548 X5.4446 Y15.8358
N549 X5.4494 Y15.8905
N550 X5.4535 Y15.9455
N551 X5.4569 Y16.0007
N552 X5.4595 Y16.0562
N553 X5.4615 Y16.112
N554 X5.4627 Y16.1679
N555 X5.4632 Y16.2241
N556 X5.463 Y16.2806
N557 X5.462 Y16.3373
N558 X5.4604 Y16.3943
N559 G2 X5.4822 Y16.4037 I0.0128 J0.0004
N560 G1 X7.6865 Y14.1994
N561 X7.6924 Y14.2038
N562 X7.6926 Y14.204
N563 X7.7047 Y14.2124
N564 X7.7078 Y14.2145
N565 X7.7079 Y14.2146
N566 X7.7295 Y14.2293
N567 X7.7273 Y14.2592
N568 M5
N569 G4 P 0.5
N570 G0 Z0.2
N571 X7.9195 Y14.1672
N572 Z0.
N573 M3
N574 G4 P 0.5
N575 G1 X7.8948 Y14.1502 F118.11
N576 X7.8967 Y14.1267 F180.
N577 X7.8999 Y14.1012
N578 X7.904 Y14.0755
N579 X7.9089 Y14.0497
N580 X7.9144 Y14.0239
N581 X7.9206 Y13.9982
N582 X7.9271 Y13.9727
N583 X7.9338 Y13.9475
N584 X7.9407 Y13.9227
N585 X7.9475 Y13.8985
N586 X7.9542 Y13.8749
N587 X7.9605 Y13.8521
N588 Y13.852
N589 X7.9734 Y13.8033
N590 Y13.8031
N591 X7.9852 Y13.7538
N592 X7.9853 Y13.7535
N593 X7.9907 Y13.7287
N594 Y13.7284
N595 X7.9955 Y13.7035
N596 X7.9956 Y13.7032
N597 X7.9998 Y13.6782
N598 Y13.6779
N599 X8.0002 Y13.6752
N600 X8.0079 Y13.6818
N601 X8.0195 Y13.6926
N602 X8.0306 Y13.7037
N603 X8.0412 Y13.7152
N604 X8.0511 Y13.727
N605 X8.0606 Y13.7392
N606 X8.0694 Y13.7517
N607 X8.0776 Y13.7647
N608 X8.0852 Y13.778
N609 X8.0923 Y13.7918
N610 X8.0987 Y13.806
N611 X8.1045 Y13.8208
N612 X8.1097 Y13.836
N613 X8.1143 Y13.8517
N614 X8.1182 Y13.8679
N615 X8.1218 Y13.8862
N616 X8.1246 Y13.9047
N617 X8.1267 Y13.9235
N618 X8.128 Y13.9425
N619 X8.1287 Y13.9616
N620 X8.1288 Y13.9809
N621 X8.1284 Y14.0003
N622 X8.1274 Y14.0197
N623 X8.1243 Y14.0587
N624 X8.1198 Y14.0975
N625 X8.1144 Y14.136
N626 X8.1084 Y14.1737
N627 X8.1024 Y14.21
N628 X8.0962 Y14.247
N629 Y14.2471
N630 X8.09 Y14.2847
N631 X8.0899 Y14.2849
N632 X8.0842 Y14.3229
N633 Y14.3232
N634 X8.0792 Y14.3615
N635 Y14.3619
N636 X8.0753 Y14.4004
N637 G2 Y14.4009 I0.0127 J0.0013
N638 G1 X8.0728 Y14.4393
N639 G2 Y14.4397 I0.0128 J0.0008
N640 G1 X8.0722 Y14.4567
N641 X8.0715 Y14.4563
N642 X8.0549 Y14.4463
N643 X8.0388 Y14.4358
N644 X8.0232 Y14.4249
N645 X8.0083 Y14.4134
N646 X7.994 Y14.4014
N647 X7.9804 Y14.3889
N648 X7.9676 Y14.3757
N649 X7.9557 Y14.362
N650 X7.9446 Y14.3476
N651 X7.9345 Y14.3326
N652 X7.9254 Y14.3169
N653 X7.9174 Y14.3004
N654 X7.9104 Y14.2832
N655 X7.9047 Y14.2651
N656 X7.9001 Y14.2461
N657 X7.8981 Y14.2351
N658 X7.8965 Y14.2237
N659 X7.8953 Y14.2121
N660 X7.8944 Y14.2005
N661 X7.8939 Y14.1764
N662 X7.8947 Y14.1518
N663 X7.8948 Y14.1502
N664 X7.9219 Y14.1373
N665 M5
N666 G4 P 0.5
N667 G0 Z0.2
N668 X7.6427 Y13.8477
N669 Z0.
N670 M3
N671 G4 P 0.5
N672 G1 X7.6172 Y13.8318 F118.11
N673 X7.6175 Y13.8218 F180.
N674 X7.6195 Y13.7977
N675 X7.6229 Y13.7733
N676 X7.6275 Y13.7486
N677 X7.6333 Y13.7236
N678 X7.6401 Y13.6985
N679 X7.6476 Y13.6733
N680 X7.6559 Y13.6482
N681 X7.6647 Y13.6233
N682 X7.6738 Y13.5986
N683 X7.6831 Y13.5742
N684 X7.6926 Y13.5503
N685 X7.7019 Y13.5269
N686 X7.7109 Y13.5042
N687 X7.711
N688 X7.7196 Y13.4822
N689 Y13.4821
N690 X7.7375 Y13.435
N691 X7.7376 Y13.4347
N692 X7.7545 Y13.387
N693 X7.7546 Y13.3867
N694 X7.7625 Y13.3626
N695 X7.7626 Y13.3624
N696 X7.77 Y13.3381
N697 X7.7701 Y13.3378
N698 X7.7769 Y13.3133
N699 X7.777 Y13.313
N700 X7.7776 Y13.3104
N701 X7.7845 Y13.3177
N702 X7.795 Y13.3297
N703 X7.8049 Y13.3419
N704 X7.8142 Y13.3544
N705 X7.8229 Y13.3672
N706 X7.8309 Y13.3803
N707 X7.8384 Y13.3937
N708 X7.8452 Y13.4074
N709 X7.8514 Y13.4215
N710 X7.857 Y13.436
N711 X7.8619 Y13.4508
N712 X7.8661 Y13.4661
N713 X7.8697 Y13.4817
N714 X7.8726 Y13.4978
N715 X7.8749 Y13.5144
N716 X7.8765 Y13.5329
N717 X7.8773 Y13.5516
N718 X7.8774 Y13.5706
N719 X7.8767 Y13.5895
N720 X7.8754 Y13.6087
N721 X7.8735 Y13.6278
N722 X7.8711 Y13.6471
N723 X7.8681 Y13.6663
N724 X7.8609 Y13.7048
N725 X7.8524 Y13.7429
N726 X7.843 Y13.7806
N727 X7.8331 Y13.8175
N728 X7.8233 Y13.8529
N729 X7.8133 Y13.8891
N730 X7.8132
N731 X7.8032 Y13.926
N732 X7.8031 Y13.9261
N733 X7.7935 Y13.9634
N734 X7.7934 Y13.9636
N735 X7.7845 Y14.0013
N736 X7.7844 Y14.0016
N737 X7.7765 Y14.0395
N738 G2 X7.7764 Y14.0399 I0.0125 J0.0026
N739 G1 X7.7699 Y14.0779
N740 Y14.0783
N741 X7.7675 Y14.0951
N742 X7.7669 Y14.0946
N743 X7.7514 Y14.083
N744 X7.7365 Y14.0709
N745 X7.7222 Y14.0584
N746 X7.7085 Y14.0454
N747 X7.6955 Y14.032
N748 X7.6833 Y14.0181
N749 X7.672 Y14.0037
N750 X7.6616 Y13.9888
N751 X7.6521 Y13.9733
N752 X7.6436 Y13.9573
N753 X7.6362 Y13.9407
N754 X7.6299 Y13.9235
N755 X7.6248 Y13.9056
N756 X7.6209 Y13.8871
N757 X7.6184 Y13.8677
N758 X7.6175 Y13.8565
N759 X7.6171 Y13.8451
N760 Y13.8334
N761 X7.6172 Y13.8318
N762 X7.6436 Y13.8177
N763 M5
N764 G4 P 0.5
N765 G0 Z0.2
N766 X7.403 Y13.4658
N767 Z0.
N768 M3
N769 G4 P 0.5
N770 G1 X7.3782 Y13.4491 F118.11
N771 X7.3789 Y13.4393 F180.
N772 X7.3801 Y13.4277
N773 X7.3817 Y13.4161
N774 X7.3862 Y13.3924
N775 X7.3921 Y13.3685
N776 X7.3993 Y13.3444
N777 X7.4077 Y13.3202
N778 X7.417 Y13.2959
N779 X7.4272 Y13.2717
N780 X7.438 Y13.2476
N781 X7.4493 Y13.2236
N782 X7.461 Y13.2001
N783 X7.4728 Y13.1768
N784 X7.4847 Y13.154
N785 X7.4964 Y13.1317
N786 X7.5078 Y13.1101
N787 Y13.11
N788 X7.5187 Y13.0891
N789 Y13.089
N790 X7.5414 Y13.044
N791 X7.5415 Y13.0438
N792 X7.5634 Y12.9981
N793 X7.5635 Y12.9978
N794 X7.5739 Y12.9747
N795 X7.574 Y12.9744
N796 X7.5839 Y12.951
N797 X7.584 Y12.9507
N798 X7.5933 Y12.9271
N799 X7.5934 Y12.9268
N800 X7.5944 Y12.9243
N801 X7.6005 Y12.9323
N802 X7.6096 Y12.9453
N803 X7.6182 Y12.9585
N804 X7.6261 Y12.9719
N805 X7.6334 Y12.9855
N806 X7.6401 Y12.9994
N807 X7.6461 Y13.0135
N808 X7.6514 Y13.0279
N809 X7.6561 Y13.0425
N810 X7.6602 Y13.0575
N811 X7.6635 Y13.0728
N812 X7.6662 Y13.0884
N813 X7.668 Y13.1043
N814 X7.6693 Y13.1207
N815 X7.6698 Y13.1373
N816 X7.6695 Y13.156
N817 X7.6683 Y13.1747
N818 X7.6664 Y13.1934
N819 X7.6638 Y13.2123
N820 X7.6605 Y13.2311
N821 X7.6566 Y13.25
N822 X7.6521 Y13.2689
N823 X7.6472 Y13.2877
N824 X7.636 Y13.3252
N825 X7.6235 Y13.3623
N826 X7.6102 Y13.3987
N827 X7.5966 Y13.4344
N828 X7.5831 Y13.4686
N829 X7.5693 Y13.5036
N830 X7.5554 Y13.5392
N831 Y13.5393
N832 X7.5419 Y13.5754
N833 X7.5418 Y13.5756
N834 X7.529 Y13.6121
N835 X7.5288 Y13.6124
N836 X7.517 Y13.6492
N837 G2 X7.5169 Y13.6497 I0.0122 J0.0039
N838 G1 X7.5065 Y13.6868
N839 X7.5064 Y13.6872
N840 X7.5023 Y13.7037
N841 X7.5017 Y13.7031
N842 X7.4876 Y13.6899
N843 X7.474 Y13.6763
N844 X7.461 Y13.6623
N845 X7.4488 Y13.648
N846 X7.4373 Y13.6334
N847 X7.4266 Y13.6182
N848 X7.4168 Y13.6027
N849 X7.408 Y13.5868
N850 X7.4002 Y13.5705
N851 X7.3935 Y13.5537
N852 X7.3878 Y13.5364
N853 X7.3834 Y13.5186
N854 X7.3802 Y13.5003
N855 X7.3783 Y13.4814
N856 X7.3777 Y13.4619
N857 X7.3781 Y13.4507
N858 X7.3782 Y13.4491
N859 X7.4051 Y13.4359
N860 M5
N861 G4 P 0.5
N862 G0 Z0.2
N863 X7.2056 Y13.0397
N864 Z0.
N865 M3
N866 G4 P 0.5
N867 G1 X7.1826 Y13.0205 F118.11
N868 X7.1843 Y13.0108 F180.
N869 X7.1867 Y12.9994
N870 X7.1895 Y12.9881
N871 X7.1965 Y12.965
N872 X7.2049 Y12.9418
N873 X7.2145 Y12.9186
N874 X7.2254 Y12.8954
N875 X7.2372 Y12.8722
N876 X7.2499 Y12.8492
N877 X7.2632 Y12.8264
N878 X7.2769 Y12.8038
N879 X7.291 Y12.7815
N880 X7.3052 Y12.7597
N881 X7.3194 Y12.7382
N882 X7.3334 Y12.7173
N883 X7.3469 Y12.6969
N884 X7.347
N885 X7.36 Y12.6772
N886 X7.3601 Y12.677
N887 X7.3873 Y12.6348
N888 X7.3875 Y12.6345
N889 X7.4139 Y12.5913
N890 X7.4141 Y12.5911
N891 X7.4269 Y12.5691
N892 X7.427 Y12.5689
N893 X7.4393 Y12.5467
N894 X7.4394 Y12.5464
N895 X7.4511 Y12.5239
N896 X7.4513 Y12.5236
N897 X7.4525 Y12.5212
N898 X7.4577 Y12.5298
N899 X7.4655 Y12.5437
N900 X7.4726 Y12.5577
N901 X7.4791 Y12.5719
N902 X7.4849 Y12.5862
N903 X7.4901 Y12.6006
N904 X7.4946 Y12.6153
N905 X7.4984 Y12.6302
N906 X7.5015 Y12.6453
N907 X7.504 Y12.6605
N908 X7.5057 Y12.6761
N909 X7.5067 Y12.6919
N910 X7.507 Y12.7079
N911 X7.5065 Y12.7243
N912 X7.5052 Y12.7409
N913 X7.5029 Y12.7594
N914 X7.4999 Y12.7779
N915 X7.496 Y12.7964
N916 X7.4914 Y12.8148
N917 X7.4861 Y12.8333
N918 X7.4803 Y12.8517
N919 X7.4739 Y12.8699
N920 X7.467 Y12.8881
N921 X7.4519 Y12.9243
N922 X7.4357 Y12.9598
N923 X7.4187 Y12.9947
N924 X7.4013 Y13.0287
N925 X7.3844 Y13.0613
N926 X7.367 Y13.0947
N927 X7.3495 Y13.1286
N928 X7.3494 Y13.1288
N929 X7.3322 Y13.1632
N930 X7.3321 Y13.1635
N931 X7.3155 Y13.1984
N932 X7.3154 Y13.1987
N933 X7.2998 Y13.2341
N934 G2 X7.2996 Y13.2345 I0.0117 J0.0052
N935 G1 X7.2854 Y13.2704
N936 X7.2853 Y13.2707
N937 X7.2795 Y13.2867
N938 X7.2789 Y13.286
N939 X7.2662 Y13.2714
N940 X7.2541 Y13.2565
N941 X7.2427 Y13.2413
N942 X7.232 Y13.2258
N943 X7.2222 Y13.2099
N944 X7.2131 Y13.1938
N945 X7.205 Y13.1774
N946 X7.1979 Y13.1606
N947 X7.1918 Y13.1435
N948 X7.1869 Y13.1261
N949 X7.1831 Y13.1083
N950 X7.1805 Y13.0902
N951 X7.1792 Y13.0716
N952 X7.1793 Y13.0527
N953 X7.1808 Y13.0332
N954 X7.1823 Y13.0221
N955 X7.1826 Y13.0205
N956 X7.2108 Y13.0102
N957 M5
N958 G4 P 0.5
N959 G0 Z0.2
N960 X7.0537 Y12.5954
N961 Z0.
N962 M3
N963 G4 P 0.5
N964 G1 X7.0329 Y12.5738 F118.11
N965 X7.0356 Y12.5643 F180.
N966 X7.0392 Y12.5533
N967 X7.0432 Y12.5423
N968 X7.0525 Y12.52
N969 X7.0633 Y12.4979
N970 X7.0754 Y12.4758
N971 X7.0886 Y12.4538
N972 X7.1027 Y12.432
N973 X7.1177 Y12.4105
N974 X7.1333 Y12.3891
N975 X7.1494 Y12.3681
N976 X7.1657 Y12.3474
N977 X7.1821 Y12.3272
N978 X7.1984 Y12.3074
N979 X7.2145 Y12.288
N980 X7.2302 Y12.2692
N981 Y12.2691
N982 X7.2452 Y12.2509
N983 X7.2453 Y12.2508
N984 X7.2768 Y12.2116
N985 X7.277 Y12.2113
N986 X7.3079 Y12.1712
N987 X7.3081 Y12.1709
N988 X7.323 Y12.1504
N989 X7.3232 Y12.1502
N990 X7.3377 Y12.1294
N991 X7.3379 Y12.1291
N992 X7.3519 Y12.108
N993 X7.3521 Y12.1077
N994 X7.3535 Y12.1055
N995 X7.3578 Y12.1146
N996 X7.3641 Y12.1292
N997 X7.3697 Y12.1439
N998 X7.3747 Y12.1586
N999 X7.379 Y12.1735
N1000 X7.3826 Y12.1884
N1001 X7.3855 Y12.2035
N1002 X7.3878 Y12.2186
N1003 X7.3893 Y12.234
N1004 X7.3902 Y12.2494
N1005 Y12.265
N1006 X7.3896 Y12.2809
N1007 X7.3881 Y12.2969
N1008 X7.3859 Y12.3131
N1009 X7.383 Y12.3295
N1010 X7.3788 Y12.3476
N1011 X7.3738 Y12.3657
N1012 X7.368 Y12.3837
N1013 X7.3615 Y12.4016
N1014 X7.3543 Y12.4193
N1015 X7.3466 Y12.437
N1016 X7.3383 Y12.4545
N1017 X7.3296 Y12.4718
N1018 X7.3108 Y12.5063
N1019 X7.291 Y12.5399
N1020 X7.2703 Y12.5728
N1021 X7.2496 Y12.6048
N1022 X7.2293 Y12.6355
N1023 X7.2086 Y12.6668
N1024 X7.2085 Y12.6669
N1025 X7.1876 Y12.6988
N1026 X7.1875 Y12.6989
N1027 X7.1668 Y12.7314
N1028 X7.1666 Y12.7316
N1029 X7.1465 Y12.7646
N1030 X7.1463 Y12.7649
N1031 X7.1271 Y12.7985
N1032 G2 X7.1269 Y12.7989 I0.0111 J0.0064
N1033 G1 X7.109 Y12.833
N1034 X7.1088 Y12.8334
N1035 X7.1014 Y12.8487
N1036 X7.1009 Y12.848
N1037 X7.0898 Y12.8321
N1038 X7.0794 Y12.816
N1039 X7.0696 Y12.7997
N1040 X7.0606 Y12.7831
N1041 X7.0524 Y12.7664
N1042 X7.0452 Y12.7494
N1043 X7.0388 Y12.7322
N1044 X7.0335 Y12.7147
N1045 X7.0292 Y12.6971
N1046 X7.0261 Y12.6793
N1047 X7.0242 Y12.6612
N1048 X7.0236 Y12.6429
N1049 X7.0242 Y12.6243
N1050 X7.0263 Y12.6055
N1051 X7.0298 Y12.5863
N1052 X7.0324 Y12.5754
N1053 X7.0329 Y12.5738
N1054 X7.062 Y12.5666
N1055 M5
N1056 G4 P 0.5
N1057 G0 Z0.2
N1058 X6.9492 Y12.1376
N1059 Z0.
N1060 M3
N1061 G4 P 0.5
N1062 G1 X6.9307 Y12.1139 F118.11
N1063 X6.9344 Y12.1048 F180.
N1064 X6.9392 Y12.0942
N1065 X6.9443 Y12.0837
N1066 X6.9559 Y12.0625
N1067 X6.9689 Y12.0416
N1068 X6.9832 Y12.0209
N1069 X6.9986 Y12.0004
N1070 X7.015 Y11.9802
N1071 X7.0321 Y11.9603
N1072 X7.0499 Y11.9407
N1073 X7.068 Y11.9215
N1074 X7.0865 Y11.9027
N1075 X7.1049 Y11.8842
N1076 X7.1232 Y11.8662
N1077 X7.1412 Y11.8487
N1078 X7.1413 Y11.8486
N1079 X7.1588 Y11.8316
N1080 Y11.8315
N1081 X7.1756 Y11.815
N1082 X7.1757 Y11.8149
N1083 X7.2112 Y11.7792
N1084 X7.2114 Y11.779
N1085 X7.2462 Y11.7422
N1086 X7.2465 Y11.742
N1087 X7.2635 Y11.7232
N1088 X7.2636 Y11.723
N1089 X7.2803 Y11.7038
N1090 X7.2805 Y11.7036
N1091 X7.2966 Y11.684
N1092 X7.2968 Y11.6838
N1093 X7.2985 Y11.6816
N1094 X7.3019 Y11.6912
N1095 X7.3066 Y11.7064
N1096 X7.3106 Y11.7215
N1097 X7.314 Y11.7367
N1098 X7.3167 Y11.7519
N1099 X7.3188 Y11.7672
N1100 X7.3201 Y11.7825
N1101 X7.3208 Y11.7978
N1102 X7.3207 Y11.8132
N1103 X7.3199 Y11.8286
N1104 X7.3184 Y11.8442
N1105 X7.3161 Y11.8599
N1106 X7.313 Y11.8756
N1107 X7.3091 Y11.8915
N1108 X7.3044 Y11.9075
N1109 X7.2983 Y11.9252
N1110 X7.2915 Y11.9426
N1111 X7.2839 Y11.9598
N1112 X7.2755 Y11.977
N1113 X7.2666 Y11.9939
N1114 X7.257 Y12.0106
N1115 X7.2469 Y12.0272
N1116 X7.2364 Y12.0435
N1117 X7.2142 Y12.0758
N1118 X7.1909 Y12.1072
N1119 X7.167 Y12.1377
N1120 X7.143 Y12.1674
N1121 X7.1196 Y12.1958
N1122 X7.0957 Y12.2248
N1123 X7.0956 Y12.2249
N1124 X7.0715 Y12.2544
N1125 X7.0714 Y12.2545
N1126 X7.0474 Y12.2846
N1127 X7.0472 Y12.2848
N1128 X7.0238 Y12.3155
N1129 X7.0236 Y12.3158
N1130 X7.001 Y12.3472
N1131 G2 X7.0007 Y12.3476 I0.0104 J0.0075
N1132 G1 X6.9793 Y12.3797
N1133 G2 X6.9791 Y12.38 I0.0106 J0.0071
N1134 G1 X6.9701 Y12.3944
N1135 X6.9697 Y12.3937
N1136 X6.9603 Y12.3768
N1137 X6.9516 Y12.3597
N1138 X6.9436 Y12.3424
N1139 X6.9364 Y12.325
N1140 X6.93 Y12.3074
N1141 X6.9246 Y12.2898
N1142 X6.92 Y12.272
N1143 X6.9166 Y12.2541
N1144 X6.9142 Y12.2362
N1145 X6.913 Y12.2181
N1146 X6.9129 Y12.1999
N1147 X6.9142 Y12.1817
N1148 X6.9168 Y12.1632
N1149 X6.9208 Y12.1448
N1150 X6.9263 Y12.126
N1151 X6.9301 Y12.1154
N1152 X6.9307 Y12.1139
N1153 X6.9604 Y12.1098
N1154 M5
N1155 G4 P 0.5
N1156 G0 Z0.2
N1157 X6.8931 Y11.6713
N1158 Z0.
N1159 M3
N1160 G4 P 0.5
N1161 G1 X6.8772 Y11.6459 F118.11
N1162 X6.8818 Y11.6371 F180.
N1163 X6.8876 Y11.6271
N1164 X6.8938 Y11.6172
N1165 X6.9075 Y11.5973
N1166 X6.9227 Y11.5779
N1167 X6.939 Y11.5588
N1168 X6.9565 Y11.5401
N1169 X6.9749 Y11.5217
N1170 X6.9941 Y11.5037
N1171 X7.0138 Y11.4861
N1172 X7.0338 Y11.4689
N1173 X7.0541 Y11.4521
N1174 X7.0744 Y11.4357
N1175 X7.0945 Y11.4197
N1176 X7.1143 Y11.4041
N1177 X7.1335 Y11.3889
N1178 X7.152 Y11.3741
N1179 X7.1521
N1180 X7.1911 Y11.3423
N1181 X7.1913 Y11.3421
N1182 X7.2298 Y11.3092
N1183 X7.23 Y11.309
N1184 X7.2489 Y11.2921
N1185 X7.2491 Y11.2919
N1186 X7.2677 Y11.2745
N1187 X7.2679 Y11.2743
N1188 X7.286 Y11.2566
N1189 X7.2862 Y11.2563
N1190 X7.2881 Y11.2544
N1191 X7.2904 Y11.2643
N1192 X7.2935 Y11.2798
N1193 X7.296 Y11.2954
N1194 X7.2978 Y11.3108
N1195 X7.2989 Y11.3262
N1196 X7.2993 Y11.3416
N1197 X7.2991 Y11.357
N1198 X7.2982 Y11.3722
N1199 X7.2964 Y11.3876
N1200 X7.2941 Y11.4028
N1201 X7.2909 Y11.4181
N1202 X7.2869 Y11.4335
N1203 X7.2822 Y11.4488
N1204 X7.2767 Y11.4642
N1205 X7.2704 Y11.4797
N1206 X7.2625 Y11.4965
N1207 X7.2538 Y11.5132
N1208 X7.2445 Y11.5296
N1209 X7.2344 Y11.5457
N1210 X7.2237 Y11.5616
N1211 X7.2125 Y11.5773
N1212 X7.2007 Y11.5927
N1213 X7.1886 Y11.6079
N1214 X7.1631 Y11.6376
N1215 X7.1366 Y11.6664
N1216 X7.1097 Y11.6943
N1217 X7.0827 Y11.7213
N1218 X7.0565 Y11.7471
N1219 X7.0296 Y11.7734
N1220 X7.0025 Y11.8003
N1221 X7.0024 Y11.8004
N1222 X6.9754 Y11.8278
N1223 X6.9752 Y11.828
N1224 X6.9486 Y11.8561
N1225 X6.9484 Y11.8564
N1226 X6.9226 Y11.8852
N1227 G2 X6.9223 Y11.8856 I0.0095 J0.0085
N1228 G1 X6.8977 Y11.9152
N1229 G2 X6.8975 Y11.9155 I0.0098 J0.0082
N1230 G1 X6.887 Y11.929
N1231 X6.8867 Y11.9282
N1232 X6.8792 Y11.9103
N1233 X6.8723 Y11.8924
N1234 X6.8661 Y11.8744
N1235 X6.8607 Y11.8563
N1236 X6.8562 Y11.8383
N1237 X6.8526 Y11.8201
N1238 X6.85 Y11.802
N1239 X6.8484 Y11.7838
N1240 X6.8479 Y11.7657
N1241 X6.8486 Y11.7476
N1242 X6.8505 Y11.7296
N1243 X6.8536 Y11.7115
N1244 X6.8581 Y11.6935
N1245 X6.8641 Y11.6755
N1246 X6.8715 Y11.6574
N1247 X6.8764 Y11.6473
N1248 X6.8772 Y11.6459
N1249 X6.9071 Y11.6448
N1250 M5
N1251 G4 P 0.5
N1252 G0 Z0.2
N1253 X6.8861 Y11.2017
N1254 Z0.
N1255 M3
(... snip ...)
N29197 G28 G91 Z0.
N29198 G90
N29199 G28
N29200 M30
Also of interest was this thread (link below), which gave me hope that an edit to a post processor file might work, but I lack the knowledge to even try that:
where the OP, calexpavel, says in MESSAGE 7 OF 14 (06-21-2019 04:59 AM):
It wasn’t adding a g0 or g1 command after g80, but i have added
gMotionModal.reset()
at the end of
onCycleEnd()
function and now it works.
Thanks!
Well… I’ve found at least 18,379 lines from your file that would need to be edited ![]()
I might could write a script to make your ngc files at least load but this would be a hack and certainly not the correct way to go about it. Hopefully @vicious1 or someone else has some fusion cam insight. Let me know if you want to try but I’d explore other options first.
LOL. I swing for the fence!
For s and giggles you could try this
test2.zip (249.0 KB)
Around line 18 or 19 the G43 is throwing me for a loop… so I deleted it entirely ![]()
OK, something else to consider…
In my advance work on trying to be ready to post files before I even had a functional table, I had actually located more than one post processor.
In my eagerness to get a first real usable cut done, I did not pay close attention to which of the post processors I selected!
I just now realized that, and I decided to methodically try each one.
As I started to do that, I saw indications that the first try was not made with the one that has “PlasmaC” in the name! Rather it seems it was with one that is listed in the Fusion Library as simply being for “LinuxCNC” …
So I reran it with the one that has PlasmaC in the name! I am headed out to try it now! Wish me success!
Hey, that’s a cool idea. I’ll have to look into the details on that.
I’m using VirtualBox to install LinuxCNC’s debian distro on top of my windows 10 machine.
From there I just run through the install docs (section 4.2) to upgrade from 2.8 to 2.9 (buildbot) to get qtplasmac QtPlasmaC
To run the qtplasmac sim go to Applications → CNC → LinxCNC → Sample Configurations → sim → qtplasmac → finally pick your flavor
