Laser TTL turn on/off
Hi Guys,
my MPCNC is up and running now.
Time for some add-ons
I have a 2W laser laying about… so I made a mount for it.
Hooked up the 5V TTL connection to pin 44 and GND… But laser does not turn on.
As I usually mill from SD card, I’m trying repetier host to turn on / off the laser using the M3 / M5 command.
But the state of pin 44 does not change…
What am I doing wrong?
Thx
Tom
Try to check
M3 o200
M42 p44 s200
I don’t know what board you are using, but…
IF it is RAMPS1.4 and you have remapped the D9 fan output to pin 44 (this is the way I use it)…
use M106 Sxxx to turn the laser ON at intensity xxx, and
use M107 (or M106 S0) to turn laser OFF
– David
After an entire sunday or reading, google searches and reading through the marlin code, I found that, in my case, the M3 and M5 commands controle pin D6 on my ramps 1.4 board.
So I have finally got the laser to fire!!
Thanks for the replies guys
Once I’ve got the laser fitted to the MPCNC, I’ll post a picture.
The mount is printing on my tevo tarantula as we “speak” :smiley:
