I measured the offset it’s about 1.5 mm out of alignment I think the linear rails i bought may not be exact thickness as the linear rails on the v1 engineering website that may affect it so I’m thinking of shimming to move bottom motor housing but outward or raise lunar rails 1 mm higher from the surface ? The left side is worse tighter
Have you tried lubricating the Z axis rods? Mine kept binding near bottom. Sprayed some wd40 dry lube and that fixed my issue. Someone more knowledgeable maybe able to provide some insight but the coupler should have a tolerance for misalignment.
If you’ve already tried the lube idk that more would change anything. Did the Z axis ball bearings move freely? Is it possible one of them is miss aligned and that’s were your offset is coming from?
It’s the xz plate and z motor mount not equal offset it should be the same for z rods I suspect linear rails different thickness even I ordered exact same # as listed in the part list
After looking closer I concur it looks slightly askew. Also make sure your couplers are seated below the level of travel your second photo looks like the top of the couple in in the way of the window.
Since you printed your own parts the Z steps on your printer could be a bit off, or really crazy elephants foot?
An easy fix might be add a couple washers under the Z bearing blocks to back that up a bit, or you could do the linear rails as well. Haven’t seen one off that far.
