I finally got around to installing the Jackpot3 from JP2. I am having an issue with Z1 motor not moving. I tried connecting it to Y1 to check wiring and it does move. If Driver B is not working, can I use C? If so, do I just need to change the pin assignments (CS, Step, Direction, Disable) for B motor 1 to match C? Here is the motor config from the file in case something is wrong:
That is very odd. ABC are controlled from the same uart chip. Make sure there is no debris on the pins for B otherwise running on C is fine. If you have any further issues this is proof and I will take care of it if anything further happens.
