Hi I put together a lowrider V4 with this and the wifi connection is very poor even though it is ten feet line of site to the router. Help ?
Post a picture of the Jackpot so we can see how the wires are routed. It’s a somewhat common issue to have poor wifi performance if wires are routed near the antenna.
It is horrible for me. Mine worked great then didn’t. I am not sure as nothing changed on my end. I ended up getting this: Amazon.com: BAKODELOP ESP32-WROOM-32U ESP32 DevKitC V4 Dev Board with Antenna (2 Pcs) : Electronics. For the price, it was a great replacement.
After changing to this, I’ve had 0 issues. I use Millmage to control it without issue.
Edited this for clarification that the WiFi wasn’t working for just me. And this was my suggested solution.
This is rare. Most boards work at 30+ feet. most times we found people routing wires over the top of the boards and that caused most all issues. Thousands of these boards were sold with only a handful of connection issues.
Sorry to be blunt about this, but I find the fact that no pictures were posted and only a link provided to an external antenna ESP is telling.
Metal enclosures or rats nest wiring are the two cases I can think of where one would need to be using that version of ESP-32.
That said, one of the things that is still great about Jackpot V1 is that it provides flexibility to the builder to use an alternative ESP-32.
If it’s working well for them then carry on.
That should fix it.
Well, I think the board maybe having issues. But it was never solid. The tablet that sat close by never had an issue and the WiFi router was right above the machine (albeit the floor above, but still). I shouldn’t have said it was horrible, but it still isn’t the greatest either.
@MakerJim No, not a single wire over it or metal enclosure. It was the printed enclosure for the LR4. The only reason I even tried the external one was because of another post on here detailing WiFi issues and then they never had them again after upgrading to this board.
Vincent the issue I was responding to was your statement that seemed factual and blanketing. If someone from outside here read that, they might dismiss the Jackpot 1 altogether just from your statement that seemed widespread not just your experience.
If you want to discuss your issues further lets start a new topic. Thousands were sold and very few had issues, most turned out to be something over the antenna physically, wires, metal box, wrapped power cords, etc. If the board boots and connects, it is basically 100% functional. If the antenna had an issue, you might get a couple of inches, and that is it.
Yeah, I am sorry about that. It must be a me issue. I should have said it was “horrible for me” and not a blanket statement. I edited my comment.
So just a followup.. moving the power cable going to the fan did mostly fix it. Jogging sometimes I would still get the occasional lag. I decided to give the new fluidnc 4.1 and Figui a spin so I put it on the other board with the antenna and slotted it in. Seems to work well.. I like the onscreen preview of the cut and am going to have a go at doing a wireless ESPNOW m5 dial pendant.
Anyways before I switched I pulled each esp32 out of the jackpot and tested outside the case away from all wires on the side of the table that’s about 8 feet away from the router. Internal antenna got 46% wifi strength The one with the external antenna gave me 74%.
Thank you for the follow up. When I was researching WiFi issues on the ESP boards, I found a lot of people who had issues with the weak signal. I also found a lot of creative solutions.
I am glad it is working well for you.
That is pretty bad all around. I test these things by going outside closing the front solid door and walking away from the house, starting at 30+ feet. Two boards with bad reception points strongly to a router issue, not two bad boards.
I get pretty good signal from my other devices and the raspberry pi on my LR2 was fine.
Might be something specific to the ESP32 and my particular router or environment.
