ahetom
(Tom)
November 8, 2023, 3:44pm
1
Hi I am trying to figure out how to run a Lightburn generated .gc file that I have on a micro SD card.
I can see the file on the SD card when it is inserted into the SD card slot of the jackpot.
I am just not sure how to run the file
Any help is greatly appreciated
Thanks
Tom
vicious1
(Ryan)
November 8, 2023, 4:00pm
2
If you click on the file name a play button will show up next to it.
ahetom
(Tom)
November 8, 2023, 5:06pm
3
I don’t get a play button
Should the file extension be .gc ?
Whent he file is generated the Device in lightburn is the GRBL laser settings for the wifi connected laser
Should I make a new GBRL laser with a different setting than a WiFi connection ?
I don’t have a UI handy right now, but there is a place where you set file filters, and I believe only those are playable.
The default in Ryan’s config is
“f_filters”: “g;G;gco;GCO;gcode;GCODE;nc;NC;ngc;NCG;tap;TAP;txt;TXT”,
try adding .gc to that, or change your extension to .gcode or one of the others
ahetom
(Tom)
November 8, 2023, 5:28pm
5
got it !
renamed the .gc to .gcode and it worked perfect
you guys are awesome !
Thanks again
Tom
vicious1
(Ryan)
Closed
March 3, 2026, 2:23pm
6
