Hi all, I am really stumped on this one. My jackpot was working fine the other day and when I fired it up last night nothing would happend. My MPCNC wouldn’t move. After logging into the WebUI, upon loading the page I was presented with the following: MSG:ERR: Showing startup log from previous panic]. I’ve tried clearing the alarm and resetting the firmware but nothing changed. I even went as far as reflashing the ESP and running the controller off the jackpot board but I keep getting the same result. Any help is very much appreciated. Thanks.
Welcome Mike,
In the Terminal on the WebUi type in $SS. Paste the results here so we can figure out what’s causing the error.
Thank you for your help. Here is what I get after running the command:
[MSG:ERR: Showing startup log from previous panic]
[MSG:INFO: FluidNC v3.9.8 https://github.com/bdring/FluidNC]
[MSG:INFO: Configuration file:config_Laser.yaml]
[MSG:INFO: Machine MPCNC Laser]
[MSG:INFO: I2SO BCK:gpio.22 WS:gpio.17 DATA:gpio.21Min Pulse:2us]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Neg Limit gpio.25:low]
[MSG:INFO: Pos Limit gpio.35:low]
[MSG:INFO: Motor1]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Neg Limit gpio.33:low]
[MSG:INFO: Pos Limit gpio.34:low]
[MSG:INFO: Motor1]
[MSG:INFO: Axis Z (-100.000,200.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Neg Limit gpio.32:low]
[MSG:INFO: X2 Axis driver test passed]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Laser Ena:NO_PIN Out:gpio.27 Freq:5000Hz Period:8191]
[MSG:INFO: Probe gpio.36:low]
ok
<Alarm|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
Can you check your config? You have a Neg Limit and Pos Limit setting for X and Y. This is what I have in my config for the MPCNC:
#X
motor0:
limit_neg_pin: gpio.25:high
limit_pos_pin: NO_PIN
#A
motor1:
limit_neg_pin: gpio.35:high
#Y
motor0:
limit_neg_pin: gpio.33:high
#B
motor1:
limit_neg_pin: gpio.34:high
Thanks again. I have a limit switch near the origin(limit_neg_pin) and one at the furthest extent (limit_pos_pin) so that is why I have both pos and neg assigned to pins. This is the case for both the x and y axis. I’m really scratching my head on this because it was working fine as I have made several projects using my mill and the laser and then out of nowhere this error came up. I’m worried that something is wrong with the ESP32 board.
Have you solved this yet? I’m having a similar error on our LowRider4.
Greetigs, tc601 and welcome to the V1 community forums.
Please feel free to create a new forum topic for your issue as machines and configurations vary.
The topics are free and we can help focus on your specific case.
