EQUIPMENT:
- MPCNC primo (build in progress)
- Jackpot controller with dual endstop firmware
- no mods, stock BOM from store.V1E.com
PROBLEM:
I’m using the FluidNC dashboard connected via WiFi - AP to the jackpot board. I have just finished assembly and just connected the motors and endstops. I homed X and both trucks are going the same direction (X+) during “pulloff”(I’m assuming). They stop and then I get the message “fluidnc homing fail. pull off travel failed to clear limit switch”. After searching the docs I noticed that the limit switches are supposed to be NC, but the lights on the controller board only light up when triggered (acting like NO switches). How do I correct this?
I have used Klipper before and in this situation I’d invert the endstop pin by adding “!” Before the pin name. And in the fluidnc wiki it states that I could need a pull-up resistor, but I am assuming that’s unnecessary for the jackpot board/kit components from V1E (please correct me if I’m wrong).
Thank you in advance
TLDR SOLUTION:
Move one wire from the NO pin to the NC pin on the endstop
