Hello,
I’ve almost build my MPCNC primo but I’m struggling with belt tensioner.
I’m not able to insert belt into them.
What did I miss ?
Do you have any advice ? Issue with belts thickness?
Thanks
Hello,
What did I miss ?
Thanks
Can you give us a picture of how things look like atm?
Press hard. I used a screwdriver for it and pushed it in. Took quite a bit of force.
The belt looks a little thick? Is it from Ryans shop? I’m at work, I’ll take a look when I come home how it looks.
+1 A liberal amount of gorilla effort and a flat-bladed screwdriver. I used a big screwdriver and used it more like a press.
The belt come from Aliexpress not Ryans shop.
From here : https://fr.aliexpress.com/item/32811217193.html
Ok, I will give it a try without cutting my fingers
Thanks
The last pic is how you should insert it. Make sure the teeth are meshing. If there are any burrs on the print, remove them with a hobby knife or a lighter.
Now stab it with the edge of the screwdriver. That’s what I did.
