I’m assembling a Burly build that I printed myself, but all the hardware is from the V1 store. (I got a full 525 build from the store in 2016, but I wanted to upgrade to a Burly and started printing just before the Primo design came out.) I got everything working but there’s vibration along both axes. From what I’ve read here, the main culprit is usually too much tension.
I actually got a torque wrench to tighten everything to 5.5 N-m, and I’m pretty sure that’s roughly how tight I had everything during my first go-round, but I’m trying to make sure it’s all as loose as possible to make sure I’m not causing any problems for myself.
So, my question: when it comes to the bolts that only hold the bearings on (not the tension bolts), if the bolts are able to turn freely, is that too loose? Should I snug them to the point where I can’t turn them by hand? (Again, this is all still under 5.5 N-m per the torque wrench.)
