I’ve got gcode generated from EstlCAM to cut a sample vinyl heat transfer sticker. EstlCAM wants to make two or three passes for each cut, plunging a little bit more each time. This leads to the cutout getting done just fine and dandy for some parts but scraping the mirror under the decal for the final pass.
I followed the setup to get the drag knife at just the right depth but since it’s plunging, and thus pushing up the drag knife itself, I’m guessing I need to do something better to set the Z home. I have the flat probe sold in the store, but since the drag knife itself is not ferrous, it doesn’t register when probing Z and I have to use the steel tubing as the probed point. Thus, the drag knife gets pushed up due to the slight difference between the tip of the drag knife and the tip of the tubes.
I’ve tried using Z babysteps while cutting to dial it in but it seems like it’s just not working - if it’s babystepped high enough to just barely cut over the course of three passes, it does not fully cut the vinyl. If it’s babystepped low enough to cut on successive passes, it will drag and fail to cut completely. This is with heat transfer vinyl that I got cheap at a craft store to practice on, so it’s still a learning process, but is there a guide or steps I can follow to dial this in a little better? It feels like I’m flailing around trying different experiments and not getting any successful cuts.
