I did my first print and it didn’t turn out great and the I realized that I didn’t save the slicer config after a made the suggested beginner settings found here. So I reconfigured slicer and saved the setting. Now when I try to print the hot end temperature heats up as per the settings and after the the skirt path is done the temperature shuts off and the will eventually stop extruding. Any Ideas as to why this is happening?
Thanks for the rapid repose. I did check that in the Slic3r filament setting tab and the first layer is set to 205 & the Other Layers is set to 203. Is this the setting your referring to? Bed is set to 0 and 0 as I do not have the bed connected yet.
