Looking for help with resolution to this error received when homing the machine. whenever I attempt to use Repetier host to home the machine, it starts homing and then before it ever gets close to either end, it stops abruptly with this error.
I have been searching for answers on this issue and I am not seeming to get any clear answers. Some thread seem to imply that I must have end stops which we have not yet gotten per the advise to not use as beginners. Also, I don’t know why that would help since it never gets close to the ends anyway.
Per one thread I found, I also tried enabling the “define ENDSTOP_NOISE_THRESHOLD 2” line in the Configuration.h of the
firmware, but that did not seem to do anything.
I tried updating to the latest Arduino beta build and the latest firmware build https://github.com/Allted/Marlin/tree/MPCNC_MRambo_T8_16T_LCD
This seemed to be the only firmware for the mini-rambo1.3. I do not yet have any LCD and I am not clear on what T8_16T implies. There is no heatbed has we are using with a Dremel for cutting form board.
Below are the logs from Repetier host.
19:54:37.575 : Printer reset detected - initalizing
19:54:37.575 : start
19:54:37.575 : echo:Marlin bugfix-2.0.x
19:54:37.579 : echo: Last Updated: 2018-01-20 | Author: (V1 Engineering, Ryan, 302)
19:54:37.579 : echo:Compiled: Dec 10 2018
19:54:37.579 : echo: Free Memory: 3639 PlannerBufferBytes: 1472
19:54:37.583 : echo:Hardcoded Default Settings Loaded
19:54:37.583 : echo: G21 ; Units in mm (mm)
19:54:37.587 : echo: M149 C ; Units in Celsius
19:54:37.587 : echo:Filament settings: Disabled
19:54:37.587 : echo: M200 D3.00
19:54:37.587 : echo: M200 D0
19:54:37.587 : echo:Steps per unit:
19:54:37.591 : echo: M92 X100.00 Y100.00 Z400.00 E100.00
19:54:37.591 : echo:Maximum feedrates (units/s):
19:54:37.595 : echo: M203 X120.00 Y120.00 Z30.00 E25.00
19:54:37.595 : echo:Maximum Acceleration (units/s2):
19:54:37.599 : echo: M201 X400.00 Y400.00 Z200.00 E2000.00
19:54:37.599 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
19:54:37.603 : echo: M204 P400.00 R3000.00 T400.00
19:54:37.607 : echo:Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>
19:54:37.607 : echo: M205 B20000.00 S0.00 T0.00 J0.00
19:54:37.608 : echo:Home offset:
19:54:37.611 : echo: M206 X0.00 Y0.00 Z0.00
19:54:37.611 : echo:Material heatup parameters:
19:54:37.612 : echo: M145 S0 H196 B92 F0
19:54:37.616 : echo: M145 S1 H240 B110 F0
19:54:37.616 : echo:PID settings:
19:54:37.616 : echo: M301 P17.98 I0.98 D83.62
19:54:37.616 : echo:Stepper motor currents:
19:54:37.619 : echo: M907 X900 Z900 E900
19:54:37.780 : N1 M11034
19:54:37.780 : N2 M11536
19:54:37.780 : N4 M11435
19:54:37.806 : N5 M111 S698
19:54:37.806 : N6 T060
19:54:37.807 : N7 M8028
19:54:43.178 : ok
19:54:43.195 : FIRMWARE_NAME:Marlin bugfix-2.0.x (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1 E CNC EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
19:54:43.195 : N10 M220 S10080
19:54:43.199 : Cap:SERIAL_XON_XOFF:0
19:54:43.199 : Cap:EEPROM:0
19:54:43.199 : Cap:VOLUMETRIC:1
19:54:43.199 : Cap:AUTOREPORT_TEMP:1
19:54:43.199 : Cap:PROGRESS:0
19:54:43.199 : Cap:PRINT_JOB:1
19:54:43.199 : Cap:AUTOLEVEL:0
19:54:43.203 : Cap:Z_PROBE:0
19:54:43.203 : Cap:LEVELING_DATA:0
19:54:43.203 : Cap:BUILD_PERCENT:0
19:54:43.203 : Cap:SOFTWARE_POWER:0
19:54:43.207 : Cap:TOGGLE_LIGHTS:0
19:54:43.207 : Cap:CASE_LIGHT_BRIGHTNESS:0
19:54:43.207 : Cap:EMERGENCY_PARSER:0
19:54:43.207 : Cap:AUTOREPORT_SD_STATUS:0
19:54:43.211 : Cap:THERMAL_PROTECTION:1
19:54:43.211 : Cap:MOTION_MODES:1
19:54:43.211 : ok
19:54:43.211 : N11 M221 S10080
19:54:43.229 : N12 M111 S684
19:54:43.244 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
19:54:43.244 : ok
19:54:43.244 : N13 T08
19:54:43.260 : echo:DEBUG:INFO,ERRORS
19:54:43.260 : ok
19:54:43.260 : ok
19:54:43.260 : N14 M155 S185
19:54:43.260 : echo:Unknown command: “M80”
19:54:43.260 : ok
19:54:43.269 : ok
19:54:43.269 : ok
19:54:43.269 : echo:DEBUG:INFO,ERRORS
19:54:43.269 : ok
19:54:43.272 : ok
19:54:43.272 : ok
19:54:49.299 : N15 G1 X50 F36002
19:54:49.305 : ok
19:54:50.826 : N16 G1 X100 F360053
19:54:50.829 : ok
19:54:52.283 : N17 G1 X150 F360049
19:54:52.287 : ok
19:54:53.778 : N18 G1 X200 F360056
19:54:53.782 : ok
19:54:55.186 : N19 G1 X250 F360060
19:54:55.191 : ok
19:54:56.585 : N20 G1 X300 F360050
19:54:56.592 : ok
19:54:57.835 : N21 G1 X350 F360054
19:54:57.842 : ok
19:54:59.315 : N22 G1 X400 F360055
19:54:59.320 : ok
19:55:00.850 : N23 G1 X450 F360051
19:55:00.856 : ok
19:55:00.866 : N24 G1 X500 F360048
19:55:00.873 : ok
19:55:03.322 : N25 G1 X550 F360052
19:55:03.326 : ok
19:55:06.002 : N26 G1 Y50 F36003
19:55:06.005 : ok
19:55:07.435 : N27 G1 Y100 F360054
19:55:07.439 : ok
19:55:08.946 : N28 G1 Y150 F360060
19:55:08.954 : ok
19:55:10.346 : N29 G1 Y200 F360059
19:55:10.351 : ok
19:55:13.129 : N30 G1 Y250 F360054
19:55:13.140 : ok
19:55:23.417 : N31 G2833
19:55:25.420 : echo:busy: processing
19:55:27.419 : echo:busy: processing
19:55:29.422 : echo:busy: processing
19:55:31.421 : echo:busy: processing
19:55:33.420 : echo:busy: processing
19:55:35.457 : Error:Printer halted. kill() called!
19:56:02.864 : N32 M99927
19:56:02.864 : N1 M11034
19:56:03.863 : N1 M11034
Pictures attached
Thanks in advance. Having fun getting this tuned up!
