Home assistant intigration?
So in the topic on stuff I don’t need, but kinda want. (because it is a flex and it’s cool) :smiling_face_with_sunglasses:
I have my vacuum on a smart switch, instead of a relay.
I know ESTLcam has buttons I can set too outputs on the board.
But why screw around with relays and stuff when I already have a smart home.
If my Home assistant would know if it was running it could put on the vacuum and a light and turn the music down.
I have also hass agent installed on my PC that has already sensors, so it would be really cool if ESTLcam can set some sensors.
Again it would be really cool but absolutely not really necessary.
You can btw set custom sensors in Hass agent so this all might be already possible.
Also Octoprint also has this!
Could do it with a power-measuring smart-switch on the router? Should be relatively easy to detect current being drawn by the router and then have an automation to do whatever like turn on the vacuum. Can have it turn the vacuum off after a minute of no router current draw, etc.
I guess it depends on how much automation you actually want.
This could definitely be done with smart plugs on each device - power monitoring would be a bonus as well. Use a unique plug with each device and a plug on the dust extractor. (Nothing would need to be done with EstlCAM - smart plugs would work for anything using those devices without requiring specific integrations/code).
When one of the switches goes on (or power monitoring shows usage), trigger the smart plug on the dust extractor.
Do the same in reverse to figure out when to turn it off.
There are some other more ‘technical’ ways (current sensors, blah, blah, blah) to do it with HA but why over complicate it?
Pay attention to power requirements and use an appropriately sized smart plug for the device being controlled. Amazon has several options for 20A handling - assuming you are on a 20A circuit, it would give you some overhead to handle device startups surge. Depending on type of dust collection you have, you’ll likely need a higher rated smart plug there as well.
Could also automate blast gates using one of the DIY blast gate projects compatible with HA. Some of those are using ESPHome which makes it pretty easy to integrate.
Example project (lots more out there): https://www.digikey.com/en/maker/projects/diy-dust-collection-automation-smart-blast-gates-with-home-assistant/6c950d28854840119afbce4b54b79a19
I like you style @TMathews lets do blast gates, but I have to put up my ducting for a year now. :slight_smile:
I do think the ESTLcam direct integration is way nicer!
But I might just do the plug due to lack of alternative.
I am not sure in other counties but here 16A is basically the only thing we use at home.
I do had issues with 16A version and not with the 20A so I am just going to get 20A,
