Hey guys, building about to build my LR4 and I have one question
About to start building out my LR4, but curious about one thing… I have every single piece to build the LR3 ready to go, but never got around to it due to building a home etc, and the LR4 came out so quickly behind it, I’m just gonna jump right into the LR4. I have the metal XZ plates for the LR3, and was wondering if those are the same? Or do I have to get the LR4 ones? Assuming I’ll need to get the LR4 ones but wanted to ask first. Thanks!
They’re different, unfortunately.
There’s no printed parts, nor any plates, that are common from LR3 to LR4.
Electronics work for either, bearings are the same. Some fastners .
Sweet, thanks man. I figured that, but wanted to make sure before I purchased. Just gotta wait for the LR3-LR4 upgrade kit to be in stock! Again, thank you!
It’s not going to be restocked, Ryan said so last week in another thread. Better buy the plates and use the affiliate links for the rest.
As Philipp noted, there won’t be refilling of the upgrade kit stock because most folks have already updated and there isn’t enough volume to make it cost effective to stock a kit that doesn’t sell.
The other thread that Phillipp mentioned is here:
From that thread, Here’s Ryan’s reply with links:
The details are here, LowRider CNC V4 - V1 Engineering Documentation
The amazon links are here, LowRider CNC V4 - V1 Engineering Documentation
You should be able to self-source from the links above.
Please keep active in the forums with a build thread, we’d love to help you get your upgrade completed.
The linear rails are the same from LR3 to LR4, which is one of the spendier components. The printed parts and XZ plates are, as already mentioned, different.
My LR3 was built on a table built for the LR2, and my LR4 is sitting on top of the LR3 right now. (The LR3 is still functional, and somewhat larger than the LR4.) I also have another larger LR4 in production, but life got in the way, as it does.
I had the same decision, I had all parts for the LR3 and I had a partial LR4 build.
I would build the LR3 first and cut the strut plates for the LR3 first and then maybe upgrade to LR4 afterwards. I feel like I a learned a lot from the LR3 build.
And I can/will take what I learned from the LR3 to the LR4 build.
Thanks for letting me know! I’ll grab the plates now!
Ok great, I have the linear rails for the LR3, just need the hardware, plates and lead screws as I noticed those were a bit longer. Not too bad, I can make this work! Thanks!
Yes, so I have a fully built LR2, was going to upgrade to the LR3, then as I said, I bought land and built a house so it’s kept me pretty busy. And in that time the LR4 came out, and my plan is to just skip the v3, and go straight into the v4. That’s the plan anyway lol.
That’s what I’d do. :slightly_smiling_face:
That’s a luxury.
Use your LR2 to cut strut plates for the LR4.
Then, build up an LR4 beam. When you’re satisfied the fit is good, the finish assembly of the LR4.
I would then skip the LR3, and use the LR2 to cut the strut lates for the LR4. That skips the bootstrapping process of cutting the LR4 struts on the temporary struts.
The LR3 is a nice bit of kit and a major upgrade from the LR2, but the LR4 is n upgrade from there. Even with 3D printed XZ plates, itˋs worth it to go to the LR4.
