Im sure this is something simple but cant figure it out if anyone can help please. I can not get my computer to find port. went to arduino and it has NO rambo file board. I type rambo under board manger and it is blank.
Hi,
It is easy
File --> Prefences --> Additional Board Manager
–> https://raw.githubusercontent.com/ultimachine/ArduinoAddons/master/package_ultimachine_index.json
Here is the Todo
https://reprap.org/wiki/Rambo_firmware#Arduino_1.6.4.2B_Board_Manager_Plugin
Michael
when i type rambo in box it is blank
Ok got Rambo pull up. Now will not find a port keeps say select a port to obtain your info. Look under port nothing there
What OS?
Window 7 it a old laptop
With windows 7, you need to install a driver for the rambo and mini rambo.
Where do I find that? And what driver?
Which version
I downloaded that file. Can you tell what need to be done to get it to notice it?
I don’t have windows installed. I haven’t installed drivers on it in a long time. Sorry.
How do you check to make sure marlin is on arduino?
Are you following the instructions on flashing Marlin firmware?:
I got the board from V1 say it was already flashed. How do you check to see if it flashed?
When you connect from repetier host, it will print a bunch of stuff. Things like author and V1 CNC. If you paste it here, I can tell you.
Here are some setting for RH. Repetier server will grab the port, and make it hard to connect from RH.
If you bought it from Ryan, it is flashed. Don’t mess with arduino.
What are you trying to do? Maybe we need to start at the top.
