Help to return to zero position
Hi, friends. What should be the reasons for the MPCNC doesnt return to zero position? Please help
When? what program was used to generate your gcode?
Hi, I am using Estlcam v9.
Also, I was cutting a square of a depron sheet and noticed that at the end of the square cutting the tool didn´t arrive at the initial cutting position.
Do you know if there is a kind of tutorial that could show me how to setup the home position?
Thanks
Silvio
I believe that is in the Estlcam options. Setup tab “CNC program End”. 3 options are At origin, Above origin, or Above last position.
Jason is correct. Just a drop down setting in estlcam.
Thanks, guys. Let me try. Bye
