Help please with Jackpot 2 and grblHAL
Hi all, I’m aware that grblHal is not the usual firmware to use but I wanted to use gSender for it’s rotary control. I little background, I installed this controller on a custom converted wood lathe. It replaced an aging Blackbox controller. I had no issues flashing the board using the grblHAL web builder and everything seems to work, however I can not change the settings. To be clear I can change the settings (I’ve only been messing with the motors so far) but the changes are not persistent. When either using the UI or the console/terminal to change setting they appear to write to the eprom but once disconnect from the board they go back to some sort of “default”. The one exception to this is the microsteps setting, it will change from the default 16 but then immediately resets back. Can anyone shed some light on this?
As you note, most of us here have not used GrblHAL- though a few of us have flashed it as an experiment.
I’ve done that but didn’t keep it on a Jackpot.
I’ll see if I have any notes but I won’t be able to check until tomorrow as my day today is full.
As far as I know, gSender works fine with FluidNC…
I know we have a couple people that have used this, but I have not yet. I can only assume it is similar to fluid. You can change the current settings and run them, but to keep a persistent change you need to write the changes to the config file that gets read at boot. In fluid we have a macro that does it. I tried googling it a bit and can;t find anything concrete. I see, $command=value, but in the end you might just need to manually change your config.h my_machine.h file.
Thanks for replying. Yeah, that’s what I was dreading. I have done some tinkering around with marlin a few years back, but I can’t say I am proficient at digging around in the config files with IDEs.
Thank you for the reply. I used gSender a few years back on a xPro v5. As I remember it had some irritating incompatibilities, but I don’t remember the specifics. I’ll dig around and see if it is still a problem.
No, nothing like marlin. This should just be a text file. I am just having a hard time finding the instructions to guide you a little more. Ahhh, looks like, my_machine.h, not the config. Still digging.
Sorry, everything I read says the changes should stick, no text edits.
I think you need to reach out to the developer about this.
Another option would be to just use the web compiler to start fresh with the settings you want.
