Growing pains
My lowrider was to low. I changed it a bit with help from @jamiek openscad script.
It grew quite large. It will now accept 10 cm foam and a 10 cm endmill. The last one I haven’t found yet with a price I will not have to sell a kidney for.
Some pictures:
Before:
After:
And from the other side:
Note the large box with opencnc-shield is now screwed down. Everything works, including autosquare. Just have to do some wire management.
I just received a kit to make the pendant for the lowrider wireless. Also another open-cnc-shield with a lot of parts to solder. That one is going to my primo together with this pendant The lowrider gets the wireless one.
Monster machine. But for foam it should be fine. :slightly_smiling_face:
2 metres from nose to neck. layers of 75mm
if you home all the way up, does the leadscrew stays in the middle or does it wobble a bit? Have a larger side aswell and noticed (with 40cmm leadscrew) it moves a lot when going up/down. It does cut fine though.
I did not notice it, but I didn’t look for it. I wil look next time.
no rush, was just interested to know as you have a large one too :laughing:
that’'s what my wife said…
Why do I get the feeling you’re into carnal?
:sunglasses: [insert whiling emoticon]
Dude that is a SkyRider. Why do you need so tall. Tools are not long.
Ooohh, that is a long tool! Have you tried it? Seems stability may be an issue. I wouls think thwe base would need widened.
I have a couple of eps insulation boards 10 cm thick. My bit is 7.5, couldn’t find a longer one for a reasonably price yet. I widened the base. It worked fine in the eps, did not yet try it on wood yet.
Kockie, where did you get the shopvac hose? I have a hard time finding the right size.
It comes off a broken vacuum cleaner
Than I’ll have to search a bit more
I bought this one: https://www.amazon.de/VIDEFLEX-SL-AS-Meterware-Stahldrahteinlage-schwerentflammbar/dp/B07M6B3PXS/
It‘s really great, you should be able to get it as well, even though you aren‘t in Germany. :slight_smile:
Thanks, I couldn’t order it in Germany but they sold it in the netherlands as well.
Now I need to find an adapter. Or model one myself.
I’ve got a few. :grinning_face_with_smiling_eyes: What do you need?
Or you can do them yourselves with open SCAD:
@azab2c did a great job remixing it. I’ve also got a “crooked” one to connect it to the dust shoe somewhere.
Oh that’s great I just need one for this one with 50mm ID. I’ll try your parametric one. Thanks
that works perfect !
The result of the growing
All layers were cut by the lowrider and further carved by hand. Eyes could open and close (resised version from James Bruton) en contained a lot of LEDs, controlled by WLED
