Grbl disable y stepper while homing x
hello
my first post on this forum :slight_smile:
i have a weird question, not sure if its possible but maybe there is a workaround
so here is the fun, i’m building a polar sand table (a dune weaver) the original one use gear and a “crash homing method”
im modding it to a belted version with optical end-stops until here all good everything homes
that’s the sequence:
First home x axis (the rotary one) to found the opto switches, once the x is aligned with the switch the y axis can home safely. all good
But as the x axis is homing the belt of the Y axis is winding around his stepper :disappointed_face: and depending on the position the y carriage will crash on one end or another
Is it possible to disable the y stepper during homing?
(im using grbl 1.1h on a cnc shiel v.3 with a nano)
Like:
$H
Disable Y stepper
Home X
Engage Y stepper
Home Y
That should stop winding the belt around the stepper
i dont mind to modify grbl but some info would be super great :slight_smile:
ill try to upload a video and pictures of the project
Super thanks in advance
If something is happening in the code to cause the Y axis to move during an X Home command, personally I would concentrate on finding out why (and fixing that), rather than trying to disable the stepper as a mitigation technique.
Usually the homing sequence touches the limit switch once, backs off, then touches again at a slower speed. Has the Y Homing actually completed, or is it doing the second home sequence?
Or is there possibly a wiring issue where the Y motor responds to X commands?
A video might help us to understand the problem better. In order to post a video, you will need to create a YouTube account, create and publish the video there (public, not private), and then post the link to the video on this forum.
Just a note that as a new user, you have to reach a certain level (Trust Level 1) to post links. It’s pretty easy to achieve, you just need to spend a few minutes reading a few different threads:
Get to trust level 1 by…
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts
You can find out where you are at in that process by clicking on your icon at the top right, selecting Profile (bottom selection on the list), and then selecting Summary and looking at Stats.
And, oh yeah, WELCOME TO THE FORUM!!!
hello
many tanks for responding so quickly
the problem i have is not from the code, i have activated grbl to run first x and then y the sequence is working as it should, the problem is mechanical,
its a rotary system, the Y stepper motor is also the center of the rotary axis (X)
so basically as the rotary axis home while the y stepper is locked the belt is winding around
not sure how to explain it
for ex if you put a rope around a tree and you pull from one side of the rope you will be puled (sorry for the weird explanation i don’t know how to put it )
if you look for tuanchris dune weaver you will see the system, min is similar but i replaced the gear with belts
many thanks again for your time
ill follow the steps to gain trust level, (and publish a video)
