GPIO.27 Flickering
Hey all, Anyone have any idea why the gpio.27 pin would flicker?
Im running a jackpot 1, lasertree k30, usb connection to lightburn. i switched it to gpio.26 and its working fine now, but i know im not supposed to. any other gpio i can use on the board, or anyone come across the 27 staying kinda on and flickering at all times?
Check the terminal soldered connections. If you overtighten the lugs you can break a solder joint. One of the main reasons the jackpot3 was developed, but it is a simple fix it you popped a solder.
I took a look at it, doesn’t look bad, should I try reflowing the joint anyway? The one under the gpio.27 header, right?
I think that is the easiest thing to check, otherwise I have never really heard of intermittent connection issues.
