Folks,
Just received my CNC parts bundle
and just going through everything. I noticed there were 5 tubes of bearings and one tube only had 9 bearings. I also have 3 bearings in a separate bag. Does the build need 52 or 53?
So on the electronic side, I installed the daughter board for the graphics controller, installed the T0 resistor, installed the ribbon cables between the Ramp and graphics controller and lastly plugged the green power connector. Powered up and all I get is a blank backlit screen on the controller. I would of thought I would get a splash screen or error???
I have no stepper motors connected, no SD card inserted. Do I need to connect this to a computer first?
I did notice there is a bridged solder joint on pins #11/#12 on the back side of the arduino board(if you count right to left on the double header) Can someone confirm this is correct?
Z
duh. Works like a charm now.
