Getting started with Jackpot on LR3
Previously (about 10 or 11 days ago) I posted a video about tramming the gantry (and also mentioned that the same software method could be used for squaring the table/machine as well). That video was titled “LowRider v3 CNC - Tramming & Squaring with Jackpot controller”:
Well, today, I finally got around to finishing the process of squaring up my table — since having switched to the Jackpot board (previously used an SKR board).
Last time I squared my table (while using an SKR board) I had used software (the “M666” G-Code command). See this earlier video for details on that:
This time I wanted to physically square it by using my adjustable end-stops.
I got it squared — wherein my “diagonals” are each measuring at 2720.25 mm. I estimate my margin of error is +/- 0.25 mm.
I could have used software again, yet this time on a Jackpot board, that process would be by editing the GRBL feature known as “pulloff_mm” which is an editable value attribute of each given axis, edited within the config.yaml file.
Since I used physical adjustments to square, I don’t need to edit my config.yaml file.
Here’s the latest video showing details on squaring with the Jackpot:
VIDEO: LowRider v3 CNC - Squaring table with Jackpot controller
So, just a quick update on my setup and use of the Jackpot:
I had mentioned here (somewhere, some thread) that I was having no success on connecting the Jackpot to a wifi “extender.” Well, recently we switched our house from cable modem internet to fiber internet, and it also meant I was able to move the new connection box to a better location within the house than the old modem box, and so now I can connect the Jackpot directly to the main wifi router, instead of bothering with an extender. The connection works, seemingly great.
Also regarding macros for FluidNC on the WebUI v3, somewhere along the way I had gotten a mistaken impression I was supposed to be typing the GCodes themselves into the “Action” boxes of the macros, and I later found out it was still supposed to be the script file names. I finally got around to putting the .g script files back on the Jackpot’s flash storage and putting the file names back into the macros settings, and my macros are working great again.
Also, I’m running the awesome “V1E” theme for the WebUI v3, created by Jason Yeager, @jeyeager
…and it works great. I really really like it! Thank you again, Jason! It looks fantastic.
Also, I previously had upgraded the firmware on the Fluid Dial pendant, and it somehow caused a confusion of the stored probing values. After checking with the dev team on what the fix was, I learned that I simply needed to do an Erase Flash (or some such) in the PlatformIO action items in VS Code, to get back to a fresh start on those built-in probe values. I did that just now when I installed both the latest “Main” branch of the FluidNC firmware on the mainboard and the latest “Main” branch of the Fluid Dial firmware on the pendant. Everything seems to be working great. [Update: I have found one issue: the Fluid Dial is supposed to be able to access and launch macros, but each time I try, it says empty file or some such.]
I’m about to prep and try to cut some 3/4" plywood for making some custom-sized “base cabinets” that are going to support a large (13’-2" x 2’-4") table top / countertop inside a new sound-mixing / video-mixing / security-monitoring station we’ve built at the back of our church sanctuary.
