I’ve been doing some investigating, using a grbl setup on my desk. I’ve found some things that have been a little confusing, but I think I’ve got to the bottom of it all, and I wanted to share what I’ve found. This is mostly from the viewpoint of CNC milling, not 3D printing.
Background information:
- G00 is a "rapid" movement command, G01 is the "linear move" command. Linear in this sense is like a line, as in not the arc commands.
- G00 is "meant" to be repositioning the bit somewhere, to do more cutting later. G01 is meant to be a cut in a line. (((I don't like to say what is "meant", but grbl acts this way, and Marlin was originally based on grbl, so I'm going with that)))
- The configuration for grbl and marlin have a max "speed", "acceleration" defined for x, y, and z.
- Marlin also has a "jerk", but it is not the derivative of the acceleraion, more on that later.
- There is also a "Feedrate" that can be set with each movement command. This is the F#, like F15 on a G01 command.
Some example G code for moving around:
Move to 100,100,0:
G00 X100 Y100 Z0
Move to 0,0,0 with feedrate set to 100:
G01 X0 Y0 Z0 F100
Set the feedrate to 1500:
G01 1500</blockquote>
* (Marlin uses the term MAX_FEEDRATE, but I think that’s confusing, so I’m always calling it “max speed” in this writeup. grbl calls it "max rate
For both grbl and Marlin:
- 1) The max speed and acceleration for each axis should be set to reasonable defaults so that you don't skip steps without doing any cutting. That will mean that when your gcode is driving around from part to part, without cutting, it won't be skipping steps. Be aware of units, because they are different in grbl and marlin.
- The feedrate determines how fast you are moving along a line. So if you are moving from 0,0,0 to 100,100,0, with a feedrate of 100mm/s, it will take 1.42 seconds to cover the 142mm along the line of travel.
- 3) The speed the machine will actually go is limited by:
- a) No single axis can go faster than it's max speed.
- b) No single axis can accelerate faster than it's max acceleration.
- c) The combined speed has to be less than the feed rate.
<li>The feedrate is remembered for any G01 commands. If you have a G01 ... F100 command followed by a G01 ..., then the second command will still be limited to the F100 speed.</li>
<li>The commands are taken as movement along a line, so even if you have dramatically different speed limits, the path that is taken will always be along the line. For example, if you move to X10 Y10 Z10, the z speed is a lot slower, so the controller will slow down the X and Y movement to stay on the line. It wouldn't make sense for the controller to finish the X,Y movements really quickly, and then do the Z movement.</li>
<li>Since the feedrate is along the cutline, and not along any specific axis, it is not a good limit on the z axis. I think this will really have an effect on toolpaths that are doing 2.5D cutting. If the feedrate is 15mm/s, it could possibly dive into or out of the material close to 15mm/s, which is probably not a good thing for the z axis. This will eventually be clipped by the max z speed, but that still might be too high when also doing a cut. Maybe the CAM software is smart enough to figure that out and ask for a lower feedrate, I don't know.</li>
For grbl:
- G00 ignores the stored feedrate, and will move at the limits for each axis. It is assuming you aren't cutting, and you're just making a rapid movement.
- G00 doesn't clear out the feedrate, so the next G01 command will use the feedrate from the previous command.
- If you set a feedrate on a G00 command, it will be stored, and ignored for this move. So G00 F100 G01 ... will have the feedrate set to 100.
- G00 still honors the speed and acceleration limits you set on each dimension.
For Marlin:
- Marlin treats every G00 command as a G01 command. This caused a few goofy behaviors for me:
After a slow cut, the bit would move very slowly to the next part. This is because the CAM program I used did something like this:
G01 X.. Y.. Fslow G00 X.. Y..The G00 was interpreted as a G01, which had the previous feedrate set. Switching your CAM software to use G01 instead of G00 won’t help. One possible solution is to add a G01 F<some fast number> to the end of each part. Then the movement between parts will be limited by the firmware again.
- The “Jerk” setting isn’t what I thought it was. I assumed it was the derivative of the acceleration, like the speed of acceleration. It actually is a step that won’t be limited by acceleration. So if the jerk is set to 4, then the speed can go from 0 to 4 instantaneously, and then follow a smooth acceleration after that. If you are trying to limit acceleration, it’s important to set this to something really small. (As a side note, Marlin’s movement code is based on grbl, but I can’t find this setting anywhere in grbl. Maybe they ditched it, or are trying to determine it themselves somehow).
How do I use this information?
- Set your firmware speed to keep from skipping steps. This is the most important. The feedrate in the CAM software isn't a good limit, because it's not being enforced when:
- You are jogging around using the screen.
- You are using G00 with a grbl controller. This may not seem like it affects you, but a lot of CAM is written for grbl like controllers, not 3D printers.
- Your firmware acceleration settings might need to change on which tool you use.
- If you are using a heavy tool, then the force needed to stop at a higher acceleration might be enough for a skip. I don't have a good idea yet of what kind of accelerations can cause step skipping problems.
- A lighter tool might be able to go faster. If you don't want to deal with that, then make it lower.
- A tool like the laser depends on the amount of time you are spending at a certain spot... Lower acceleration values mean that the laser might be spending more time on an area than the gcode intended. I haven't spent much time looking at the laser stuff, maybe there's a clever way they fix that, but if not, setting the acceleration higher would minimize this issue.
- When using marlin, add a feedrate command before any non-cutting movement commands. This will let the bit move as fast as the firmware will allow, which still shouldn't skip steps. In EstlCAM, I think there's an area where you can define some gcode when a path is finished.
What do you think? Is this explaining anything you’ve had questions about? Am I wrong about anything up there? Is there more useful info anyone can share?
Oh well.
