I’ve been working on getting engraving working on my machine, but can’t seem to get the hang of using the V-Bit and the Engraving tools in Fusion 360. I’ve been using Fusion for pretty much all my CAM needs with MPCNC and it’s been awesome but running into some stumbling blocks here.
I think the crux of the issue is getting the right settings for the 1/8th inch V-Bit (purchased here). What happens is that the generated toolpaths aren’t necessarily pulling the bit all the way out to the point when it’s exiting the letter. At first I thought it might be an origin issue, but that doesn’t seem to be the case as I’ve validated it with other cutting operations and don’t have an issue.
Right now I have the cutting edge set for:
3.175Mm DIameter
3.175mm Shaft Diameter
45 degree taper angle
0.1mm Tip diameter
I know this is an old thread, but Ryan is there any chance you are able to list the tool data in the V1 shop listing so we don’t have to guess/measure/figure this stuff out for each tool we buy from you? The 45/22.5 degree thing went over my head as well until I saw this thread.
It depends on the software you use for how angles are entered vetric you enter 45 estcam 45 fusion 22.5 so that gets confusing also. A entry in the milling basics page is where that belongs
