Fusion 360 Post Processor Errors
Fusion 360 Just did a big update.
Now when I try to post process for MPCNC
Using the MPCNC.CPC file
I get a whole page of errors.
Job: CNC Firmware: Parameter has unknown value ‘metric?0:0’. Try editing its expression.
Job: Comment Level: Parameter has unknown value ‘metric?2:2’. Try editing its expression.
Laser: Marlin/Reprap Mode: Parameter has unknown value ‘metric?106:106’. Try editing its expression.
Laser: GRBL Mode: Parameter has unknown value ‘metric?4:4’. Try editing its expression.
Laser: Coolant: Parameter has unknown value ‘metric?0:0’. Try editing its expression.
Coolant: A Mode: Parameter has unknown value ‘metric?0:0’. Try editing its expression.
Coolant: B Mode: Parameter has unknown value ‘metric?0:0’. Try editing its expression.
Coolant: A Enable: Parameter has unknown value ‘metric?M42 P6 S255:M42 P6 S255’. Try editing its expression.
Coolant: A Disable: Parameter has unknown value ‘metric?M42 P6 S0:M42 P6 S0’. Try editing its expression.
Coolant: B Enable: Parameter has unknown value ‘metric?M42 P11 S255:M42 P11 S255’. Try editing its expression.
Coolant: B Disable: Parameter has unknown value ‘metric?M42 P11 S0:M42 P11 S0’. Try editing its expression.
Yep.
Discussed here:
And new version with fix is here:
Version 3 fixed the issue. Thanks
