Fusion 360 Machine Setup
Im looking for some help setting up machines in Fusion 360. In the pic below, can these numbers reverse the axis orientation? I have zeroed my machine on a specific corner and set that same corner as the origin point in Fusion 360, but when I start the cut, it is starting with the X axis reversed.
So I am trying to figure out what actually determines where the home position is set up inside F360 because I have it working the way I want on the actual machine.
I’m assuming you want to put the work origin at the machine origin/home.
Sounds like you already figured out where to set that point in the fusion job setup, but you also have to make sure the arrows point the right way. You can click the pointy end of the arrow or check the box that says “reverse axis”.
The only other gotcha is that your axes have to obey the right hand rule, and it’s possible to choose a corner and direction that will not. If you think that might be the problem, share a picture or sketch and we can work through it.
