Problem : The button knob on my Full Graphic Smart Controller works with button presses but does not register knob rotations.
I bought all of my hardware from the V1 store in August '18 and started building a Lowrider. The project got set aside until this month. I have everything wired-up with my Mini Rambo. No smoke on the initial power up (yay!). After the initial splash screens I can toggle between the info screen and the top level menu screen but cannot rotate the knob to change the menu selection. I’ve triple checked the connections and re-seated the connections but no luck.
Has any one seen this before? I suspect a bad controller board.
Thanks
Kevin
Edit: Also the Reset button doesn’t work and the controller doesn’t recognize an SD card when one is inserted
