FluidNC 3.9.9
OK. I think it’s all working ok.
  • restored color scheme in Terminal from WebUI 2
  • implemented cached rendering so it doesn’t re-render the entire message stack on every update
  • added Max Terminal Messages setting for control. default is 400
If someone wants to give it a test, you can pick up the build artifact here: index.html.gz.zip (see next message)
You’ll need to unzip the .zip to get access to the .gz file to put on the ESP32
I only have the ability to run it in the simulator right now, but if a few people can put it through its paces, I’ll make it official
I have only a disconnected ESP32 to test with right now, but seems ok
