Fluid Dial (Fluid NC dial pendant by Bart Dring, using M5 Stack's M5 Dial)
Thanks @MakerJim @Britt @DougJoseph appreciate the response, I was away so just getting back now. So I was following the guide which shows this wiring like this
Are you saying I should connect to the VMot connector vs the 5v connector? Note I am talking the CYD here not the M5.
Thanks again, I will otherwise try these settings tonight.
