Really hoping someone can help me out here, Im pulling my hair out!
I’ve just upgraded my original mpcnc to the primo and added dual end stops. All good until I tried to flash the firmware.
I’ve tried both Arduino IDE and Platform io.
The error comes up in arduino as:
“An error occurred while uploading the sketch”
above that it says:
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : wiring
Overriding Baud Rate : 115200
Make certain that you’re specifying the right USB connection, and that you don’t have another program connected to the USB device. I’d forget to disconnect in Repetier Host and get that error when trying to flash firmware.
Appreciate the replies. What fixed the issue was manually installing drivers as com port in device manager using ‘add legacy hardware’. After this the firmware flashed fine.
Now I have another issue. The stepper connected to E1 (Y2) now seems to move much further than 1mm when I use the LCD controller to test movement. All other steppers working as they should.
Thanks Jeff. Didnt know to check these. There are non under that driver! I assume all three are needed as per other drivers. I dont seem to have any spare from anything. I dont supose you know what size they are?
Yep. IIRC, without those jumpers it will drive 32x faster! In a pinch, you could also just solder the two pins together, but that’s a little bit like wedging in a coin because you haven’t got any spare fuses.
