Fitment of idlers
Hello all, I found that, in order to fit the idlers into the trucks, I had to file off the built in (washers)(see photo) once inn, there is no way they will spin w/o the built in spacers.
The trucks were printed on a Bambu X1 carbon using carbon PLA 3 wall thickness and 45% infill
The spacers were purchased from here.
Everything else so far has fit together perfectly
So far, here are my options:
  • Change print settings, material, machine.
  • Remodel the trucks in Solidworks (doesn’t seem like I should have to do this, as this doesn’t seem to be a common problem)
  • Find different spacers (even though I got them from v1)
Any suggestions would be appreciated
That print looks really rough for a Bambu X1C (which is what I have). You shouldn’t have to do any of those work arounds. Did you orient the part correctly and use the recommended settings? How old is the PLA? What brand is the PLA? The only time I have seen rough prints like that is when using cheap PLA or CF style filaments.
IRL, the parts look super clean. The rough texture is due to the carbon fiber. It is Bambu brand carbon fiber PLA right out of the package. Settings are default Bambu carbon PLA settings with 3 walls and 45% infill. I am now running some test prints with different filament. Doing some test prints on my old Raise 3d machine too.
Thanks for the response.
I see. Yeah, PLA-CF is going to be rough. Did you follow the advice here: LowRider CNC V4 - V1 Engineering Documentation ? PLA-CF isn’t listed but should be fine. I do know that every time I have used any CF filament, it isn’t as smooth fitting as filament without the CF.
These parts do not look clean to me either.
See circled areas. What layer height and nozzle size are you using? Looks like under extrusion at the top which can be common with filaments that have included fibers.
I got to the bottom of it. I made four test prints using 4 different materials on 3 different machines (see photo) The spacing for the idlers on all 4 came out between 13.70mm and 13.80. Then I measure the STL in Solidworks. The spacing is 13.60mm (see photo). No way a 14mm idler is fitting in there.
My question is, how could this have worked for anyone?
My plan is to return the idlers to V1 and try to find ones that are less than 14mm (I think I found some 13mm ones on Amazon)
Otherwise I have to try to alter the truck design
Any other ideas would be greatly appreciated.
.20 layer height with .4mm nozzle. The photo looks rough, the parts look nice, and more importantly, they measure out correctly.
Is the bearing in the idler flush with the idler surface, or is it inset a little? A 0.34mm difference should allow insertion with a little bit of flex I would have thought, especially if the bearings are inset slightly from the idler sides.
Bearings are exactly flush. No way those idlers are getting in there without considerable material removal. I tried on all 4 test parts.
After a little filing and a whole lot of leverage, I was able to get them into my PETG test part. I believe this is due to the flexibility of PETG and the fact that it has 2 layer walls and 15% infill. (Printed on the Raise 3d pro3) I could not achieve this with the Carbon PETG or PLA test parts.
Edit. Mabe I shouldn’t apply my engineering experience here, but I don’t think an interference fit would be appropriate in an assembly of parts like this.
The idlers look wrong. I don’t remember the MPCNC trucks looking like that either though, but it’s been a while. :sweat_smile:
I just searched the store to compare and it states
“The height of these can vary, if the fit is too snug just shave down the printed spacers for any of the V1 designs.”
https://www.v1e.com/collections/lowrider-parts/products/20t-idler-gt2-10mm
Interesting. Those obviously don’t seem to fit. :sweat_smile:
The problem is that, when I shaved the spacer enough to get the idler in there, there was no spacer left, and the idler wouldn’t spin.
Thanks.
The red part in the photo is not the whole truck. I cut it down in the slicer to save time and material, as it was a test part.
The new idlers are a bit wider than we used 6 years ago, and the primo parts are pretty old were designed to fit the old idlers. Just sand out the cavity enough for them to have some room and you will be fine. The screw holds the position, and the exact position is not critical at all.
I can say I highly recommend an LR over a primo , it has a slightly higher upfront cost but a smaller footprint and much higher performance.
Thank you Ryan.
The problem with the idlers isn’t the width, it’s the height. The width is 15mm which leaves plenty of room. It’s the 14.0 mm height. The STL only allows for 13.60mm . Once enough material is removed, the spacers are gone, and the flange of the idler hits the radius of the underside of the motor mount causing it not to spin.
Regarding machine choice, if l’d known the MPCNC was such a bad idea, I would have gone with the LR. But now that I’m $600 into the project (very little of which is returnable or translatable to the LR) I feel kind of locked in.
We are talking about the same dimension. Bearing to bearing. Just scrape out what you need to get them in.
The primo is still a great build, it is just two generations behind the LR at this point. If you build it small, you will get the same performance.
So it’s not a problem if they don’t spin?
Sand off more plastic until they do, use a utility knife if you have to. They don’t have to spin like a fidget spinner but get them so they can rotate.
Okay. Thank you :folded_hands:
