Feed Rates / Manual Over-ride in Repetier
Machine is up and running, and I’ve got to hand it to vicious… this is a nifty little tool.
I know that i’ve read on here that 200mm is the max x-y feed rate. I also know that feed rate is subjective to the material being cut, the depth of cut, number of flutes on the bit, and spindle speed.
Repetier has the manual feedrate override for lack of a better word… my question is: does that change the feed rate between 0-300mmpm or is that 0-300 percent of programmed feed rate?
Thanks.
Percent, but You can’t increase it past the firmware limits.
