F360 post processor
So I’ve had my lr4 done for a few weeks now but have been battling f360 post processing. I’ve tried writing my own modifying existing with no luck. Either erroring out or invalid or does t work the way it should. Does anyone with knowledge on this wanting to help me out? It’s for a plasma set up with probe being floating head
@DougJoseph Take over here? :stuck_out_tongue:
It’s been a while since I was down in the weeds on this. I think I would have included post(s) about which post processor I use for Fusion in my plasma build log. Also there was a checkbox option about curves and I remember something about that needing attention— and hopefully I’d have posted about that too. Did you check my plasma build log?
I have not but I will look into it tonight thank you !!
Do you know off hand if it outputs the correct gcode for probing. That has been a lot of my battle and when I modify ones that have a different gcode I error out
I am not sure if my probing is happening as a feature of my user interface or the Gcode. My UI is QTPlasmaC, running in LinuxCNC.
Ah ok so your set up wouldn’t work for me since I’m trying to utilize fluidnc which uses different probe commands as far as I can tell
It may be that the probe commands are being created by the post processor as the project is being outputted by Fusion. I’m just not up on it enough to know for sure.
Have you seen this?
You can add an external file for start or end commands (ie for probing)
