ESTL Cam Pause ignored
Hi,
I am new to CNC and have been building a few simple things, however am at the point where I would like to do some tool changes. I used some code I found on here but when I compile the gcode and run it, when it gets to the pause line it appears to just skip it and continue on, which does not allow me to physically change the tool. I’m not sure if someone can please point me in the right direction?
If I type in the pause manually it appears to work. Also please note that I do not have a touch panel, I do everything from the web interface.
Thanks!
M107 ; Turn fan 1 off IOT relay
G28 Z ; Raise Z axis
G0 X0 Y0 F2520 ; Drive to tool change side
M00 change tool, probe ; Pause to change tool and attach probe.
G38.2 Z0 ; Probe to touchplate
G92 Z0.5 ; Set Z to touchplate thickness
G00 Z5.0000 F500 ; Lift off touchplate
M00 remove probe ; Pause to remove touchplate
M106 ; Turn fan 1 on IoT relay
Your M00 commands have the semi colon in the wrong place
Should be M00; change…
Also, you should probably do a re-home of X and Y after as well (in case you inadvertently move the core when changing the tool)
And welcome to the Forum!
omg! :joy:
Thank you!
