Estelcam v12069a does not open in full screen
Hi,
I have the following phenomenon.
Each time I open my Estelcam v12 version it comes up with a reduced screen, I must click maximise in order to get it full screen.
It is not a big issue but annoying.
Does more people recognise this?
Yours,
Frans.
Yes. It somewhere even says so. Some programming reason. Just drag it as big as possible, then it will be like it the next time.
It is an easy fix. Right click on your shortcut and then open properties. In properties there is RUN, click on that and select maximum
Thanks for your reply, I have set it to open as maximise but is stays the same.
Estelcam opens full screen and than jump back to 3/4 screen.
Click on maximise most right corner symbol will set it back to full screen.
Or if I while Estelcam is open right click in the most top part of the Estelcam screen I can click maximise, Estelcam will be at full screen.
My Estelcam v11 works fine regarding screen size appearance.
I’ll send an email to Christian, I believe it is a small bug.
kind regards,
Frans.
Estlcam 12 only remembers the last manually set window size, any use of Maximize will not be remembered, i.e. as Philipp said, the window has to be manually maximized for it to be remembered.
Hi Dave,
Thanks for your reply.
I have manually stretched the Estelcam window and this seems to work.
By all means I tough I have done this, but apparently not.
Estelcam v12 opens now wit full size window.
regards, Frans.
