Error 1 expecting Gcode line 1
The following program was hand written in NC Viewier and runs fine in that environment. My MPCNC Primo has been working fine with tweaked Fusion 360 programs (removing residual spindle speeds etc.)
My machine won’t get past line 1, reporting back an Error 1 Expecting a Gcode letter. Help please?
G21
G17
G92 X0 Y0 Z0
G91
; Above set zero location, XY plane, Millimeter units, Relataive
; Program mills 13 6mm dia holes in a row, 9mm deep starting from X=0 Y=0
; after positioned above far right position manually ie. program moves to the left.
; Move to position that puts the 1/8" mill to the outside edge of a 6mm hole
G01 X-1.413 Y0
; Clockwise 1/2 circle to other side of 6mm hole allowing for tool dia.and begin descent by .25mm per 1/2 revolution
G02 X2.825 Y0 Z-.25 R1.413 F100
G02 X-2.825 Y0 Z-.25 R1.413 F100 ; Finish circle back to beginning
; Repeat circle and step down until 9mm
G02 X-2.825 Y0 Z-.25 R1.413 F100.... etc
Thanks in advance for the help,
Cleve
Forgot to add controller is the V1 Engineering Jackpot controller purchased late last year.
That looks okay to me, Are you sure there is not a blank line or line numbers or something?
Can you post the contents of the terminal or FluidTerm when you get this error?
Are you trying to run this code from SD card using the WebUI, or using a sender program?
If a sender, which one?
Did the forum line-wrap this, or is this the actual output? My guess would be the “1/2 revolution” line needs commented out.
Thanks all for your replies.
Taking a working program I tucked my code for the new program in after the first few lines, using Notepad as the editor. It worked
Desiring to make some tweaks using NCViewer because it has line counts I ‘saved’ that (it downloads the file), but subsequently it didn’t work.
Same changes made in notepad did work. So convinced that the download saving process from NCViewer must be the problem.
Thanks again for taking a look.
