I have been using my Primo for sign making lately. I purchased a carbide engraving/signmakers bit for my router.
However, the letters do not come out exactly square at the edges. The edges of this “n” and “t” should be just 90 degrees - instead the router makes this little concave shape and small rounded points at the ends.
Any suggestions to how I can avoid this? The machine is dead accurate, so I suspect it has something to do with the tool setup.
This didn’t happen with my old V bit, even though it had a blunt point (offset), and this new bit has a sharp point.
Anyone using a similar bit that could share their tool profile, perhaps?
Using Estlcam for gcode and Repetier host for machine control. I use the “carve” function in Estlcam.
