My end stops no longer work as they should. If the truck trigger them, nothing happens.
I ran m1119 and they all show open. I ran m119 while triggering each one indivudally and the corrent endstop shows triggered whhen doing so.
My Z stops workings as it should.
I just upgraded to the latest firmware with no success.
Make sure the first and second endstops are associated with the first and second steppers, respectively. If the X1 motor runs into the X2 endstop, it will stop the far motor and not itself.
And also check the grub screws. Although that would be the opposite problem.
Its a mpcnc.
I double checked the end stops are associated with the corresponding motors. Ive manually triggered the stops while the motors were running also, it had no effect.
Endstops will only stop the motors during homing. Any other time they are ignored. So if you are just moving it from the screen they endstops wont stop them. If you are doing homing and they don’t stop it then you have other issues.
