I have a Donek drag knife. My goal was to cut out foam board airplanes ala FliteTest. A drag knife ought to give better edges than a pin cutter, at least that was my theory. Quieter too.
However, we’re not getting good corners at all. We’re trying to use the corner actions excel spreadsheet from Donek.
Is anyone doing drag knife work that can help me figure out what to do differently?
I have a Donek drag knife as well… but not being a Windows/Excel-kinda guy and reasonably happy with the cuts I get with my needle cutters – I’ve never seen reason to pursue it. I suspect that, even if you can get those corner actions dialed in, the “crown” (and similar detail) might always present problems
[attachment file=100129]
[attachment file=100130]
[attachment file=100131]
[attachment file=100132]
[attachment file=100133]
[attachment file=100134]
The fuzziness is, of course, the bottom-side paper on DTFB… note the foam is cut very cleanly. Un-papered foams cut beautifully.
Yeah, the knife is quieter… maybe not the operator
My current needle cutters utilize a new slip-on flywheel I developed in conjunction with my version of Mark “moebeast” Moebes’ LowRider-inspired Foam Ripper (https://www.thingiverse.com/thing:2520214). I documented the build (with mods). of both the machine and the needle cutter in my FliteTest needle-cutter thread, starting here
