Okay so first off:
- Did you buy everything from here? Yes, about a year ago. I have not changed anything from stock.
- Are you using end stops? Nope
- Mac or PC? PC
I built my machine over a year ago and am only now getting around to actually learning how to use it. So far things have gone pretty well except I am noticing that I’m not getting the travel I would expect in the Y axis. I’m not noticing any shaking or binding in any axis, and my tensioner bolts are pretty loose. I’ve attached Gcode from two runs. Heartinkscape.gcode is an approximately 50x50 heart shape carved 2mm deep with a v-groove bit. As you can see in the attached image, there seems to be some shifting or something going on in the Y axis on the left bottom and top right side of the heart. The text, which was carved before the heart outline, seems almost perfect, except the right side of the “M” is a little high. The second job, square.gcode, is supposed to be a 100mm x 100mm square, and was cut as a part using a 1/8" diameter double fluted end mill. I don’t have my tool settings in front of me, but I know I used the conservative settings outlined in the set up guide. As you can see in that image, the X axis came very close at 99.4mm, but the Y axis only reached 95.5mm. It looks a little distorted in the picture, but I did verify it has perfect right angles at the corners, and the frame of the machine itself seems to be pretty square, so I’m not sure what is going on here. Any ideas what to check next? As I said, the hardware was bought from Ryan over a year ago - do I need to update firmware or anything? Thanks! - Jeff
MPCNC-Gcode.zip (17.8 KB)
