Determining job starting point.. struggles
@vicious1 Thanks for creating the Estlcam docs.
Read the docs a few times, but I ran into similar issue.
Problem/cause: Gcode created by EstlCam I downloaded yesterday does not start with G92 0 0 0
Which Estlcam setting would generate gcode with G92?
Workaround: Currently, I’ve configured Repetier manual control button 1 to run G92 0 0 0 script. I click on the button 1 script before kicking off a job.
Also, the EstlCam doc image shows arc setting enabled, but this results in crazy visualizations in Repetier. I’ve been deselecting arc setting in EstlCam to work around for now. Guessing that results in poorer quality curves, larger gcode sizes.
