So i have a nice thick beautiful piece of oak to use for my chessboard.
However my first initial test cuts are not working.
Im getting a TON of vibration in my D660 near the bit. I think its too hard of a wood.
So about 4 inches per minute? I would think that is plenty slow even for a hard wood. How far down does the bit hang out of the DW660? What mount are you using for the DW660? Is the bit good and tight or does it seem just kind of tight?
i dont know the conversion but in ESTLCAM i set it to 2mm/s.
Bit hangs down kinda far, thats a good point, i will try that… that seems VERY realistically an issue.
using the normal thingiverse mount for the 660.
bit is tight, but hanging down.
1/4" at 5mm/s with 4mm depth of cut worked great… i think its just a more stout bit… all looks good.
im engraving and cutting my chess board now… SO EXCITING
